Replacing Bushings
Old May 24, 2013 | 08:29 AM
c4_4ya's Avatar
c4_4ya
Default Replacing Bushings
I'm upgrading the suspension on my 92 to z07 specs, and plan to change out any worn bushings I find which I'm sure will be most of them. What tool or tools are best for pressing suspension bushings in and out? Everything from end link bushings to control arm bushings. Just a decent 12 or 20 ton press or is that complete overkill?
Old May 24, 2013 | 08:50 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Default Bushings
A good small shop press or a c clamp rig of some type may work but if going with poly type bushings, most are two piece not requiring a press for install like the rear control arms, camber rods, end links, and batwing. Didn't know if you have got bushings yet or if going with poly ,but I have a full set of poly rears on the C4 FS: forum if interested.
If not, please disregard this post.
Rick
Old May 24, 2013 | 09:10 AM
LoneStarV's Avatar
LoneStarV
What bushings are you planning on using? Poly or global west del a lum? If you use a press be sure to brace the control arms or you will warp and ruin them.
Old May 24, 2013 | 09:27 AM
c4_4ya's Avatar
c4_4ya
Trying to stay all factory/rubber except maybe on the sway bar and end links. I've got the end links out now, and raybestos rubber bushings with the metal shell. So a small shop press like a 12 ton should suffice for any/all c4 suspension bushings I would ever need to do?
Old May 24, 2013 | 09:35 AM
LoneStarV's Avatar
LoneStarV
You can't get rubber control arm bushings. It's either poly,global west del a lum, or you buy new control arms.....they aint cheap.
Old May 24, 2013 | 01:49 PM
c4_4ya's Avatar
c4_4ya
Yep, very true. I found a set of z07 (z51) front arms with good looking LCA bushings, so hopefully they won't need replaced for some time. However, I do have the originals I can put either of those in to have on-hand and ready to go.
To Replacing Bushings
