Plug below the throttle body???
Old Jun 23, 2002 | 03:18 PM
siberianhusky911's Avatar
siberianhusky911
Default Plug below the throttle body???
On a 86 auto z51. Can some one tell me what the plug below the throttle body and the IAC is? It looks like it plugs into the block it has a green ring around it and it has 2 prongs to plug in. I just found my with the wire cut. Thanks Ron
[Modified by siberianhusky911, 7:37 PM 6/23/2002]
Old Jun 23, 2002 | 04:10 PM
Corvette0096's Avatar
Corvette0096
Default Re: Plug below the throttle body??? (siberianhusky911)
On the intake manifold?
Old Jun 23, 2002 | 07:09 PM
siberianhusky911
Default Re: Plug below the throttle body??? (corvette0096)
Ya i think its on the manifold
Old Jun 24, 2002 | 12:38 AM
Corvette0096
There is a couple sensors down there. One is for the cold start injector, That one wont trow a code. That is the one on the drivers side. There is one more down there and i forgot what that one is for.
Old Jun 24, 2002 | 10:14 AM
Jim85IROC's Avatar
Jim85IROC
There are 2 coolant temp sensors on the front of the intake manifold, right next to each other. The one with the injector-style plug is the cold start sensor, and the other one is the one that the ECM uses.
To Plug below the throttle body???
