grease for polyurathane bushings
Old May 25, 2013 | 08:03 PM
Impala Balko's Avatar
Impala Balko
Default grease for polyurathane bushings
I am installing polyurathane bushings and the kit came with, what I think is, too little lube... What kind of lube do I use because the stuff that came with looks almost like vasaline.
Old May 25, 2013 | 08:13 PM
cumbercr's Avatar
cumbercr
I'm just starting my suspension rebuild. I ordered the bushing grease from Mid America. From what I've heard, you can also use marine grease.
Old May 25, 2013 | 08:57 PM
RestoRoc89's Avatar
RestoRoc89
Energy suspension formula no. 5 is what you want. That's what Pfadt supplies with urethane products. Pretty much any performance shop should be able to order it for you. It's extremely sticky (doesn't ooze out of the joint as fast as other options) and does well at preventing water ingress.
Old May 25, 2013 | 11:31 PM
Impala Balko
does summit carry it
Old May 25, 2013 | 11:55 PM
1985 Corvette's Avatar
1985 Corvette
I used Moly Grease on mine. Auto parts stores sell them in tiny tubs. Works on any area exposed to the elements and requires lots of staying power.
Old May 25, 2013 | 11:56 PM
Impala Balko
do you need to really slather this stuff on or is a thin layer good enough
Old May 26, 2013 | 12:03 AM
1985 Corvette
Putting a lot on won't hurt, just ensures it gets everywhere. Wipe the excess away and you are good to go. When you torque the bolts down, that may squeeze some additional out. Can't hurt to put it on the face of the bushings so there are no squeaks from that metal to urethane contact. Some guys drill holes in their dog bones and sway bar brackets, install a zerk fitting and routinely lube the suspension pieces with a grease gun
Old May 26, 2013 | 04:14 AM
RestoRoc89's Avatar
RestoRoc89
http://www.amazon.com/Energy-Suspension-9-11104-Formula-Prelube/dp/B005BDA67S?tag=5336118839-20 http://www.amazon.com/Energy-Suspension-9-11104-Formula-Prelube/dp/B005BDA67S?tag=5336118839-20
This ought to do the trick. Slather it on liberally...and plan to re-grease on an annual basis if you want to avoid the dreaded squeaks. Polyurethane bushings do not usually come without their headaches (though I feel the performance benefits make dealing with them worthwhile). Note that many manufacturers of polyurethane bushings indicate that you should avoid using petroleum based lubricants.
Old May 26, 2013 | 12:19 PM
1985 Corvette
Originally Posted by RestoRoc89
http://www.amazon.com/Energy-Suspens...=5336118839-20
Yeah can't hurt to use the manufacturers recommended lubricant on it. My urethanes have been coated in moly grease for over a decade. Popped them out about a year ago and they feel just as new as they did the day I coated them and pressed them in.
Old May 26, 2013 | 02:14 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You have enough to do the job.
Believe it, or not.
Old May 26, 2013 | 02:16 PM
ToniH's Avatar
ToniH
Marine grease. It will stay in there nicely and you won't end with squeaking bushings. 12+ years with mine and not a squeak.
Old May 26, 2013 | 02:46 PM
mcm95403's Avatar
mcm95403
This stuff is awesome: http://polybushings.com/pages/bushinglube.html
To grease for polyurathane bushings
