#2 Spark lug w/OBX headers
Old May 26, 2013 | 06:25 PM
lgaff's Avatar
lgaff
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Default #2 Spark lug w/OBX headers
Had to loosen the header to get #2 plug in, not sure about the clearance to the plug wire....anyone else dealt with this issue?
Lee
Old May 26, 2013 | 07:15 PM
383vett's Avatar
383vett
Sounds too close
Old May 27, 2013 | 10:56 AM
ghoastrider1's Avatar
ghoastrider1
mine is so tight, I have to use a wrench to tighten the plug. No room for a socket, much less an extension, wobble, or ratchet.
Old May 27, 2013 | 11:23 AM
lgaff's Avatar
lgaff
Any issues with the plug wire burning?
Old May 29, 2013 | 12:28 PM
Rohn's Avatar
Rohn
I have straight plug heads with 1 + 5/8 hedman headers. I recall 2 of 8 are close. I use a "max access" Craftsman socket wrench. Well named.
Old May 29, 2013 | 02:17 PM
WW7's Avatar
WW7
You aren't the first to have trouble with this brand of header..Read the link below...Send them back and get TPIS, Hooker, Stainless Works, EM, or one of the other brands known to work properly on our cars. You should not have to loosen the headers to get plugs in.......WW
http://forums.corvetteforum.com/c4-g...uy-unless.html
Old May 30, 2013 | 09:09 PM
THE 383 admiral's Avatar
THE 383 admiral
You did not mention if you have a L98 or LT1
After market heads?
I cut my plug socket about 1" and use a 19mm or 3/4 box wrench
I have angle plug SBC heads converted to fit my LT1 block & as everyone tries to say the "cheap" OBX
Is so bad!! Mine fit perfect..
Even $2,000 headers are not perfect!! & can have fitmit issues!!
Old May 30, 2013 | 09:28 PM
THE 383 admiral
The "max access" kit is a great alternative!!! I have the 58pc kit.. and did not think of using them... THANK's
Old May 30, 2013 | 10:19 PM
Mountain 55's Avatar
Mountain 55
I have the OBX headers. I will tell you the area to work when placing the #2 spark plug is tight but can be done without loosing header bolts. In fact, they can all be done. You just have to figure out the right combination of rachets, shorty wrenches etc.
Old May 30, 2013 | 10:25 PM
lgaff's Avatar
lgaff
This is a friends car, I ported the stock LT-1 heads and added 2.00 1.56 valves.....#2 plug was tough and not sure how to keep it from burning/melting the wire boot.
Also the first bolt hole on #8 was not aligned and was a PITA to thread......
Old May 30, 2013 | 11:57 PM
THE 383 admiral
Are you positive your friend purchased the LT1 set
My # 2 is a lil over 1" away my # 4 is closer. but not close enough to get burnt. Both are well below the header tube
Maybe they have the wrong plugs? or defective plug thats very long?
I have super conductors the boots are very thick.
Old May 31, 2013 | 06:30 AM
Mountain 55
Some of my boots/wires were close also. I put protective sleeves on all of the wires which also cover the boots for added piece of mind.
To #2 Spark lug w/OBX headers
