Would you be worried,about 230 engine temp?
A radiator is fairly cheap $125 or so. Also get a "fan switch" that turns on the fans earlier. Once you're moving at 40+ the fans don't do anything it's all airflow at that point. That's why I'm betting your radiator is clogged.
A lower temp stat will be okay if you fix the mechanical problems but otherwise will just make the overheating worse.
Mine would hit 240+ climbing a long grade in 90 degree ambient and I've got almost every cooling system upgrade that's been made..
I recall the temps while driving the mountains in Az or Ca in the summer...
To answer the fan question...
the primary fan is ECM controlled and the ECM is semi dormant when the engine is off and key is ON. Its not going to react to anything unless the engine is running...so the main fan sits still. Temp rises due to the coolant not flowing to drop off heat in the radiator. The block is still very hot and the second that coolant stops moving the heat is trapped there where the CTS (sensor) is.
The aux fan (that can't be seen) is on a simple switch that is activated as soon as that switch reaches 230 degrees give or take, thru a ground. The switch itself is the ground, so whenever there is power to the switch, and a ground path, the fan runs. That fan is mounted in front of the condenser and CAN be seen by looking up, in the nose at the a/c condenser. That fan is very good for collecting trash and will eventually catch something that will break a blade or just cause it to burn up. Its NOT a 'gotta have' item..in fact it was added by dealerships in response to owners freaking out when they saw their car hit 230 in traffic with the a/c running,.,..it really does little to help. Its a placebo if anything. The car cools by forward motion. Yes, it gets hot sitting still. It has no access to fresh air until its moving. The main fan was designed to fill in those gaps where the car sits and idles and the ECM turns that main fan off after the car reaches a certain speed. About 35 mph IIRC...
To clean the radiator of leaves and grocery store bags and news papers, you MUST take the top radiator shroud off and dig the debris out that's between the radiator and the a/c condenser. There is NO way to see this, or access it without taking the top shroud off. 1st time is hardest, but if you make some simple modifications by a couple cuts on the shroud it is a 10 minute job the next time. Just 'slot' the part that passes over a hose and the trans cooler lines. Cake after that.
beware the dead things that live between the rad and condenser...there will be fur, feathers and sometimes bones. You don't wanna know...
Buying a FSM set will be the best investment you will EVER make if you plan on doing much at home service of the car. Search FleaBay for used sets for $75.
Flush the system, refill with good clean green coolant or whatever you like, (just be damn sure its compatible) and clean the debris out of the airstream and you're good to go.
