Repurpose c 4 corvette
Old Jun 1, 2013 | 12:46 PM
S C CARS's Avatar
S C CARS
1st Gear
Default Repurpose c 4 corvette
New member & i need help. I have a well used 94 c4. I am going to use as many of the parts & pieces as i can in a 66 chevy p.u. I will attach all suspension parts to a custom built tubelar frame. I would like to eleminate as much of the unnecessary wiring as possible. Would like to use ecm, suspension control, instrumentation, & any system that that has to be used to make motor run. Any help would be appreicated.
Thanks,
bill @ s c cars
Old Jun 2, 2013 | 01:01 AM
leesvet's Avatar
leesvet
you're not going to loose much...
the cars ECM has sensor input from just about everything and everywhere. Guess you could do without the antenna wires...hatch wires....light harness. beyond that, you need everything to the trans, all around the engine bay and the for corners for brake/abs input. If you are not going to use ABS then it MIGHT need to be tuned out so the system is not looking for it. Not sure how/if the abs is linked to the bcm or ecm.
