Mini Starter With Headers?
Old Jun 2, 2013 | 12:58 PM
My1st's Avatar
My1st
Default Mini Starter With Headers?
I put my headers on yesterday and found the starter is too big as the motor hits the tubes and I’m unable to get the staggered bolt in. There’s no way to line up the holes. So it looks like I’ll need a mini starter.
I see they make them in OEM style with the motor on the bottom and also on the top with the solenoid on the bottom.
Does it matter which one you get?
It seams with the motor on top there may be fit issues too?
Has anyone encountered problems with either style?
Is one brand better then the other?
Just how much smaller is a Mini compared to OEM?
Old Jun 2, 2013 | 01:44 PM
LD85's Avatar
LD85
I assume you have an early C4,
I bought the newer Corvette mini starter for my 85, you can get one at Autozone, lifetime warranty,
http://forums.corvetteforum.com/c4-t...into-85-a.html
Old Jun 2, 2013 | 02:02 PM
gman35's Avatar
gman35
Default early c4
did you put tose headers on a early C4?? i am getting ready to install a set of long tube ceramic coated hooker headers on my 1987 c4. and was wondering about difficulty thanks gary.
Old Jun 2, 2013 | 02:07 PM
JackDidley's Avatar
JackDidley
I also got one from a newer C4. On my 87 it was all I could do to make the big cable reach. Sort of a good thing since I dont have to worry about it hanging down and touching something it should not.
Old Jun 2, 2013 | 02:15 PM
WW7's Avatar
WW7
If you have an 89 like your profile says, it should already have a mini starter on it ,, Mine did and it's a factory starter, they stopped using the larger starter in 88.......WW
Old Jun 2, 2013 | 02:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
The minis that are clockable are nice. You canflip the solenoid upside down so its low and out of the way depending on your headers.
Old Jun 2, 2013 | 10:07 PM
My1st's Avatar
My1st
It is an 89 and did have a mini on it until I put the 400 in and had to go to a staggered bolt starter. I did keep the starter from the L98 but for the life of me I'm unable to find it.
Old Jun 3, 2013 | 12:53 AM
Calderone's Avatar
Calderone
I Got the hitachi starter and fits with 68448 hedman hedders with no problems
Old Jun 3, 2013 | 12:58 AM
leesvet's Avatar
leesvet
The mini I got states on the label that it'll turn over some outrageous high comp engine...like diesels.
My engine is bigger and comp is 10.5:1 and that lil mini spins it like a top... way mo-betta than the boat anchor delco ever did.
BUT
it sounds like a dodge 4 cyl turning over....
The mini is probably 40% less weight, and about that much smaller too. I had a similar issue with the fat delco unable to come out unless I loosened the collector and pushed it over so the starter could come out...PITA
No more ! the mini will go in/out...with one hand !
Old Jun 3, 2013 | 06:26 AM
blackozvet's Avatar
blackozvet
I have just put my new mini starter in on the weekend, like cuisinartvette said they are "clockable" so i set mine over towards the engine block to get it as far away as possible from the hedman headers, here is a comparison photo,
the hard part is getting the wiring where you want it, I put my wiring under the starter and came up the block side, you maybe could try hanging the solenoid upside down (i didnt think of that !) I also put heat sleeve over the wiring and heat wrap on the 3 pipes near the starter,
its hard to get a good photo, but here's one,
Old Jun 3, 2013 | 07:20 AM
My1st's Avatar
My1st
Thanks for all the replies. I don’t see any problem fitting a mini with the headers.
I literally had the rest the starter on the header and us a floor jack to lift on the collector and lift from the top at the same time to get the starter in place to get one bolt in. Those darn things are heavy lifting with one hand lying on your back.
Sure wish I could find the one that was on the L98 but than again it wasn't staggered but the new roller 350 soon to go in has bolt holes for either staggered or straight.
Old Jun 3, 2013 | 07:44 AM
LD85's Avatar
LD85
I can take my stock 1996 mini on an off with my headers on, and it starts my 11:00.1 CR
Old Jun 3, 2013 | 09:23 AM
c4cruiser's Avatar
c4cruiser
So what's a good brand recommendation for a mini starter to get for my '87 when I install my Hedman 68448 headers? Powermaster, Tilton, MSD, Summit Racing (in-house brand)?
Old Jun 3, 2013 | 07:49 PM
My1st's Avatar
My1st
So with a clockable base the motor can rotated to be on top or bottom? Is this true with all that are clockable? I’m concerned if the motor is on top like most I’m seeing I’ll still have fit issues with the headers.
Old Jun 4, 2013 | 07:46 AM
My1st's Avatar
My1st
BLACKOZVET, where did you purchase the DSM I'm unable to locate them on the internet? Part number? Looks like that one would work and is clockable. Thanks
Old Jun 4, 2013 | 08:04 AM
blackozvet's Avatar
blackozvet
this one is sold by a vendor from Sydney Aus on ebay, Im pretty sure its a copy of the MSD starter, hence the name DSM,
go onto summit and type in "mini starter" , they have a lot of similiar ones at a good price.
Old Jun 4, 2013 | 11:58 AM
c4cruiser's Avatar
c4cruiser
Look in the Summit Racing website for staggered-mount mini-starters Powermaster makes mini starters with the offset bolt pattern for SB Chevy (p/n PWM-9612, p/n PWM-9426, and p/n PWM-9526) or the Summit house brand starter (SUM-820323-OS).
Old Jun 4, 2013 | 12:12 PM
88BlackZ-51's Avatar
88BlackZ-51
i have a mini starter off my 88 if u want to buy it......works perfect.
To Mini Starter With Headers?
