Fuel pressure problem
Old Jun 3, 2013 | 08:24 AM
vtormane's Avatar
vtormane
Default Fuel pressure problem
I installed a fuel pressure cauge and pressure is around 39-36psi.
My problem is that the pressure drops suddenly to 15-20psi when I drive the car. Of course car drives horrible.
I have changed the fuel filter, no help.
When the pressure is ok and I turn off the engine, pressure stays up for many hours.
What can I test next? I heard about dynamic fuel pressure test but I haven't found out how to do it.
Old Jun 3, 2013 | 03:25 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would take a look at the fuel sock in the tank and the hose running from the pump to the steel line, also in the tank.
Old Jun 3, 2013 | 03:43 PM
mixalive's Avatar
mixalive
Time to replace the fuel pump and sock. It is very easy on the Corvette. And buy the Made in USA Weber. The Edelbrock unit uses a Weber pump.
Old Jun 3, 2013 | 03:48 PM
vtormane's Avatar
vtormane
Where can I buy such unit?
Old Jun 4, 2013 | 01:41 AM
leesvet's Avatar
leesvet
all you need is a new pump. They come with a strainer.
if you want a good one, the racetronix is a very popular upgrade.
These pumps wear out because everyone insist on driving hard with less than 1/2 tank of gas. Can't do that. The pump is cooled by being submerged in gas and the first time the pump sucks air it damages the rubber impeller. They do not like to be run hot or dry...
Half of what is found in fuel filters WAS/IS part of the pump as it disintegrates and sends chunks to the injectors.
Old Jun 4, 2013 | 11:09 AM
mixalive's Avatar
mixalive
Edelbrock sells the same pump as Racetronics. Summit Racing, Jegs and even Advance sells it online.
Summit also sells the Granatelli GRN-GM722-2 for $125. It is probably a Weber as well. The cheapy $69 pumps are probably not Weber.
Old Jun 10, 2013 | 04:39 PM
vtormane's Avatar
vtormane
Thanks to everyone. Another question. I measure about 12.6 volts from the fuel pump wiring harness when the car is running. At the same time I can read 13.7 volts from the battery. Is this voltage drop normal and will the fuel pump run correctly with 12.6 volts?
Old Jun 10, 2013 | 04:52 PM
aklim's Avatar
aklim
Racetronix. I'd get it but not the other harness to run power from the alternator unless you have a power issue.
Old Jun 10, 2013 | 04:55 PM
aklim's Avatar
aklim
I think that is an old wives tale. At that rate, I'd be changing my pump every week. My car runs down to the bottom then gets filled up.
If it needs that much cooling, it would be a fire hazard. As long as fuel flows thru it, it is cooled. Now if fuel stops, the engine cuts out and the pump stops so no heating
Old Jun 12, 2013 | 05:07 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
voltage drop normal. That pump will run on 9 volts. Don't worry about the incidentals.
To Fuel pressure problem
