1992 to 1995 optispark harness
Old Jun 6, 2013 | 01:25 AM
Atl_monte's Avatar
Atl_monte
Default 1992 to 1995 optispark harness
I have a 1992 Corvette I recently installed an 1995 Lt1 in and was wondering how to address the issues with the optispark harnesses; I have the extention harness for the 1995, was wondering can I just cut off the ends and splice the wires? Or is it more that must be done? Also where do I run the vacumm line/vent?
Old Jun 6, 2013 | 11:00 AM
aboatguy's Avatar
aboatguy
Vent line source runs from the air intake bellows to the opti. and the vacuum line runs to the intake.
Old Jun 6, 2013 | 01:50 PM
bassackwards's Avatar
bassackwards
I have a 92 and ran into this same problem with a 93 optispark.
You can remove the car side of the plug by sticking a pin in and releasing each clip. They then just slide into the new connector and snap into position. The metallic shield wire can be removed or folded back and secured.
To 1992 to 1995 optispark harness
