I've seen this topic come up before but couldn't locate the right info when I searched for it.
I have a 1989 with the FX3 active ride control. The shocks need replacing and the shop says they are no longer manufactured and want to convert it to a standard setup.
I have a 1989 with the FX3 active ride control. The struts need replacing and the shop says they are no longer manufactured and want to convert it to a standard setup.
Is my only option to located some used struts?
Bilstein still rebuilds the shocks...somewhere I have their number to call.
I think you can also find it on their web site. If you send 2, you may as well send all 4 because chances are they are ALL the same age. Consider the other 2 on borrowed time.
some of the aftermarket vendors have been selling new or remanufactured versions. try Mid America or Ecklers. Mine have been non-functioning for a few years. The problem is the "pot-metal" sproket on the top of the shock crumbles after a while and the computer can't adjust the shock. I'm going to forge some new ones out of aluminum and see if it fixes the problem better.
That little socket can be replaced. I had one break on mine. I bought a new one from Volunteer Vette and replaced it. Been working ever since. Cheap and easy fix. A rebuild on all 4 shocks would be nice, but it's about $250 per shock.
Yeah, Bilstein called me back and it's $210ish per shock + shipping. I went ahead and paid Corvette America $370. It's definitely more, but Bilstein can't cross ship so it would add a week and a half to the time in the shop.
I bought new Bilsteins for my 1994 ZR-1 which is equipment with the FX3 option this March from http://www.eshocks.com/bil_veh.asp?M...=All&SubChar=Q. You may want to check them out. If you do, make sure you buy the shock mounting kits also as they do not come with the shocks.
