How do I check fuel pump pickup screen?
Old Jun 24, 2002 | 06:53 PM
Lone Ranger's Avatar
Lone Ranger
Default How do I check fuel pump pickup screen?
I want to check the pickup screen on the fuel pump, is it a changeable part if it should happen to be obstructed with junk? I've run the gas down to about 1/8 tank. How do I go about getting to the pump and pickup?
Old Jun 24, 2002 | 07:11 PM
Corvette0096's Avatar
Corvette0096
Default Re: How do I check fuel pump pickup screen? (Lone Ranger)
First thing kill the power from the battery and remove the torks bolt on your gas cover. Remove rubber boot, remove the screws that are on top of the tank holding the pump assembly. Lift up and the screen will come up with the pump. Remove fuel lines to ;)
Old Jun 24, 2002 | 07:17 PM
Lone Ranger
Default Re: How do I check fuel pump pickup screen? (corvette0096)
Do you have to completely drain the tank 1st? How do you unhook the fuel lines without gas spewing all over? Thanks :D
Old Jun 24, 2002 | 07:19 PM
Corvette0096
No the fuel lines are up at the highest point of the system
Old Jun 24, 2002 | 07:23 PM
Lone Ranger
Cool :cool: Thanks!
P.S. What's best brand of smokes to drag on whilst doing the job?
:D Just kidding :D
Old Jun 24, 2002 | 07:26 PM
Corvette0096
The green stuff. The ones you have to roll by hand.. :lol:
Old Jun 24, 2002 | 07:28 PM
gtsyellow's Avatar
gtsyellow
i prefer to use a propane torch or oxy/acc cutting torch to loosen up those hard to get fuel lines. also works well to weld up gas tanks on the car :lol: smoking while you do this is just an added benifit
Old Jun 24, 2002 | 07:29 PM
Corvette0096
Default Re: How do I check fuel pump pickup screen? (gtsyellow)
Lol :lol:
To How do I check fuel pump pickup screen?
