Wheel Adapters
Old Jun 7, 2013 | 11:46 PM
85BlackVette's Avatar
85BlackVette
Default Wheel Adapters
Im looking to buy adapters to fit on my 85 for my 5 spoke ZR1 style wheels. Getting tired of looking at them sunkin in the wheel wells. Im debating on getting the 1.25" or 1.5". Let me know your thoughts? Also if anyone has pics that would be great. Thanks guys!
Old Jun 8, 2013 | 12:09 AM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
What size wheel are you looking for 9.5X17 and 11X17?
There are aftermarket one that have the correct offset....
Old Jun 8, 2013 | 12:57 AM
WVZR-1's Avatar
WVZR-1
Generally speaking 1" adapters are used when putting 9 1/2" later wheels on an early car. It's difficult to comment with out knowing what you have installed on there now for wheels. Can you tell us? 1 1/4" would likely fly but I'd guess 1 1/2" might be a stretch.
What you could do is drop a plumb-bob from the hood edge to the ground and measure from the tire side-wall to the string and any dimension less than that would tell you where the wheel/tire would sit by adding that thick of a spacer. You could do it from the quarter edge in the rear and compare also.
That would be cut and dried, no guessing.
Old Jun 8, 2013 | 01:18 AM
Cliff Harris's Avatar
Cliff Harris
Here's the definitive chart of Corvette wheel sizes and offsets. That should give you the info you need to choose the appropriate adapter:
http://corvetteactioncenter.com/tech...l#.UbK-YZX5HHM
Old Jun 8, 2013 | 04:29 AM
blackozvet's Avatar
blackozvet
I used 1" spacers on my 85 with 88 (17 x 9.5) wheels and they are just right
Old Jun 8, 2013 | 08:30 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Go with the 1", the wheels are out just far enough where it look's good and you shouldn't rub the upper fender well. My first set were 1.5 and ended up selling them. Be sure to get adapters that are wheel & hub centric.
Old Jun 8, 2013 | 02:08 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Go with the 1".
I had 1.25" and used them on my '85 with '94 sawblades. The fronts (8.5" wheels) are ok with the 1.25" adapter, but would be too far out with 9.5" wheels. The rears are ok with the 9.5" wheels but they are all the way out as far as I would use.
The 1" or even 0.75" would be a better choice.
Here is what the 1.25" looked like on my '85.
Old Jun 9, 2013 | 10:14 PM
85BlackVette
Thanks for all your replies everyone, great information and much appreciated. I already have the 17X9.5 spoke wheels from a later model C4 on there now so I leaning toward the 1.25" adapters. Ebay has them but just need to figure out what seller and brand to go with. QCVette, I like that look with the 1.25"...However for those that went with the 1" did you need to grind down the stock studs at all?
Old Jun 9, 2013 | 10:28 PM
WVZR-1's Avatar
WVZR-1
Pull one of your wheels and between each wheel stud hole there should most likely be a recessed area and you may likely not need to trim/grind a thing.
I'd suggest doing a 1" buy first and then if you actually believe the 1 1/4 will work the 1" would be an easy sell. You buy the 1 1/4" and your not happy they're not going to be the easy sell.
You lived with the "misfits" for how long?
You need to be sure that you're buying adapters that have a center bore of 70.3 to fit the car and have a 70.3 hub to fit the wheel. If you don't do that you've accomplished near nothing!
Old Jun 11, 2013 | 06:10 PM
85BlackVette
Ive lived with these misfits way to long, for years. Still have no idea how ive gone so long without correcting it. I did buy adapters a while back from Ecklers and couldnt get them to work right and just gave up. Also was going to sell or trade for a manual Vette so just left it the way it is. Well this year im going to get it right because its driving me crazy looking at them tucked in the wells..... Thanks for the info....
Old Jun 13, 2013 | 11:50 AM
85BlackVette
Where did you guys get your wheel adapters? It looks like if I go with the 1" the stock studs will stick out and the lug nuts might be to long and will stick out as well. I just got the 1.25" to try them out and it fits just right with no mods but the wheels come out a little far in the front. I have the ZR1 style aftermarkets and it only has a small cut out in the back and probably not deep enough where the studs and lugs will fit in. Going to keep the pair for the rear and maybe go with the 1" for the fronts if I can find the right ones. Thanks
Old Jun 13, 2013 | 01:39 PM
cumbercr's Avatar
cumbercr
I got 1" adapters off eBay. They fit fine with my 88-96 offset wheels. I tried a set of 3/4" adapters but the acorn adapter nuts interfered with the wheel.
To Wheel Adapters
