Engine RPM question
Old Jun 24, 2002 | 07:36 PM
Chief Muktar's Avatar
Chief Muktar
Default Engine RPM question
I've noticed that on my 1990 6-speed in 6th gear @ 70 MPH my engine is running just under 2000 RPM. I believe that the only gear ratio available is a 3.33 ?? It seems like the motor is spinning higher than it should. Could a previous owner have installed a different gearset in the car? The only other thing I can think of is that whoever owned the car before me installed some 235/45/17 tires. (don't even ask me why:mad ) Anybody have any ideas?
Old Jun 24, 2002 | 08:43 PM
HighHopes85's Avatar
HighHopes85
Default Re: Engine RPM question (Chief Muktar)
Tire OD = 25.327 inches...
I figure 4.1X gears will put you at 1900 RPM at 70 MPH with a 0.5:1 6th gear ratio.
Old Jun 25, 2002 | 10:59 PM
dlmeyers's Avatar
dlmeyers
Default Re: Engine RPM question (HighHopes85)
Hello,
I have a 90, zf6 with 3.33 gear set, 275-40 ZR17's. At 70mph, she's tach'in 1750rpms.
Hmmm.
dlmeyers 90 coupe zf6 3 speed shocks
Old Jun 26, 2002 | 12:39 AM
Chief Muktar
Does this use a 275/40/17 tire or a 235/45/17 tire??
Old Jun 26, 2002 | 01:00 AM
HighHopes85
Tire diameter is sidewall profile times treadwidth. 50 series means sidewall is 0.5* the height of the tread width. 40 means the tire is 0.40* the treadwidth. That is in millimeters. Multiply by 2 since the diameter includes 2 sidewalls (bottom and top of tire IOW). Add the height of the wheel and you have tire diameter.
LOL. I typed too fast. 'Add' wasn't quite what it was supposed to be and the censors tore it up :D
I did the calcs with the 235. i.e....
(235*0.45) * 2 = 211.5mm
211.5mm = 8.32677 in
8.32677 in + 17 in = 25.32677 in
25.32677 in = 0.003197824 furlongs = 0.0003473533 nautical miles
[Modified by HighHopes85, 11:09 PM 6/25/2002]
Old Jun 26, 2002 | 05:57 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Make sure your tachameter is correct. All most every 90 model has problems with the factory tach reading high. Some are worse than others but many including me have factory tachs that are off by as much as 2500-3000rpm. In most cases the higher the rpm, the more rpm it will be off by.
Old Jun 27, 2002 | 12:42 PM
Chief Muktar
Default Re: Engine RPM question (red90sixspeed)
Whats the best way to determine if the tach is reading correctly?
Old Jun 27, 2002 | 01:04 PM
Wheelman's Avatar
Wheelman
i believe a scan tool hooked up to your aldl port will give you a rpm reading.
To Engine RPM question
