Help with Diagnostic Trouble Codes
Old Jun 8, 2013 | 03:55 PM
Mohammed_z's Avatar
Mohammed_z
Default Help with Diagnostic Trouble Codes
Pulled the codes today from my '94 and I got those,
C12
H48
H43
H67
H24
DTC #48: Mass Air Flow Sensor Circuit.
DTC #43: Knock Sensor Circuit.
DTC #67: A/C Pressure Sensor Circuit Sensor or A/C Clutch.
DTC #24: Vehicle Speed Sensor Circuit.
what is c12 ?
Does h43,h48 and h67 mean I have to replace the sensors ?
Old Jun 8, 2013 | 07:15 PM
airplane50's Avatar
airplane50
C12 code relates to the PKE and is - DTC #12: Receiver Memory Bad
Hope this helps.
Old Jun 8, 2013 | 09:02 PM
STL94LT1's Avatar
STL94LT1
Wouldn't think three sensors would go bad at once. Possible PCM issue?
Sorry I missed your PM.
-Mike
Old Jun 8, 2013 | 09:30 PM
blue94's Avatar
blue94
not 100% positive but c is current and h is history so I would clear first then monitor.
have you reflashed and is the speedo working?
Old Jun 9, 2013 | 03:26 AM
Mohammed_z's Avatar
Mohammed_z
Hope this helps.
alright , thanks
-Mike
Hey Mike , the knock sensor wire was cut i think it gone bad again and the speedo is not working.
The speedo is not working , although i replaced it with a new one.
Old Jun 9, 2013 | 03:44 AM
Cliff Harris's Avatar
Cliff Harris
C12 is no distributor reference pulses. That is because the engine is not running. It is frequently listed as "no problems", which isn't accurate, but it is used a delimiter to flag the begin and end of the list of error codes.
Old Jun 9, 2013 | 01:36 PM
STL94LT1's Avatar
STL94LT1
Does the speedo do anything? Did it stop working after any other changes?
Old Jun 9, 2013 | 02:58 PM
Mohammed_z's Avatar
Mohammed_z
sometimes it reades 2,3,4 kmh.
It stopped working after zf6 swap.
Old Jun 9, 2013 | 03:02 PM
STL94LT1's Avatar
STL94LT1
Did you have the PCM reflashed for the ZF6?
Old Jun 10, 2013 | 06:28 PM
blue94's Avatar
blue94
The ECU is still set for an automatic, reflash it for the manual and speedo will work. Deselect switch table entry automatic transmission is the only change needed. My 94 had same issue after zf6 swap and that is the only change required to get it working.
If the tune bin file you sent was current just use the bin file sent back to you and your speedo should work. The only change was the one switch table entry.
To Help with Diagnostic Trouble Codes
