IAC question
Old Jun 9, 2013 | 09:19 PM
wedgeheaded's Avatar
wedgeheaded
Default IAC question
My 90 L98 runs great but has a miss, stumble, I don't know what, at idle and just off idle. I'm not having any luck running it down. I thought it might be a bad IAC so I read the resistance on the coils in the IAC with my VOM. Both sides are made and read the same resistance. Now here's my question, even though both sides are made and read the same, could it still be bad?
Old Jun 9, 2013 | 09:46 PM
don hall's Avatar
don hall
Have you checked for trouble codes?
Old Jun 9, 2013 | 10:12 PM
wedgeheaded
Code check said it had low voltage to the TPS and something else. I wrote it down but I'd have to find my notes to see what it was. Anyway, I checked both and they both had 5 VDC. I honestly haven't found anything specific. I found a vac leak and thought I had it but not. I've bought new intake gaskets as it seems worse when everything is warmed up. I thought it might be a vac leak around part of the intake that opens up as it warms up. I haven't put it in the car yet though.
Old Jun 10, 2013 | 02:46 AM
Cliff Harris's Avatar
Cliff Harris
Check the voltage on all three terminals of the TPS.
Ground your meter to a bare metal part of the engine. Ignition on, engine NOT running (unless you like having moving parts near where you're trying to work). The top terminal should measure 5 volts (reference voltage from ECM). The middle terminal should measure about 0.5 volts (the FSM calls for 0.54 volts, but we're just trying to find out if there's a fault here). The bottom wire should be 0 volts (ground).
If the middle and bottom wires are 5 volts then the ground is missing somehow.
Old Jun 10, 2013 | 01:19 PM
wedgeheaded
I verified both the 5 volts to gnd and to the bottom terminal. (which in turn verified a good gnd as it read 5 volts. I'm not sure how I can test the center pin though. Once I unplug it to read it, I have no voltage on it. Or, an I missing something?
Old Jun 10, 2013 | 04:05 PM
aklim's Avatar
aklim
3 wires. 1 is the 5V reference, the other is the ground and the 3rd is the output. I suppose if you hook it all up, you can tap into the line and get a voltage coming out of the TPS. I prefer to use a scanner so I can see what the ECM sees but tapping the wire to the ECM works too.
Old Jun 10, 2013 | 04:40 PM
RWDsmoke's Avatar
RWDsmoke
The IAC should only affect the idle speed. Keep looking for that vacuum leak.
Old Jun 10, 2013 | 05:32 PM
cgantner5150's Avatar
cgantner5150
Back probe the TPS sensor while it is connected and key on (engine not running). Middle terminal (positive) and ground (negative) should read 0.54 VDC. Operate the throttle by hand slowly - it should smoothly raise the voltage to 4.5 to 5.0 VDC at full throttle.
You stated that you had a code for low voltage TPS. A bad TPS will cause all kinds of problems.
Old Jun 10, 2013 | 07:58 PM
wedgeheaded
I hate to just change parts and see what happens. I pulled the EGR tonight and it was filthy. I cleaned it well and made sure the diaphragm was working. I put it back in, no change. I had high hopes for that. I'll not give up. It's getting personal now.
Old Jun 10, 2013 | 11:07 PM
wedgeheaded
I cobbled up a jumper to let me test voltages on the TPS. 5VDC on the top post to the bottom post. (Bottom post reads common with gnd.) The center post reads 4.4 VDC to gnd. It measures .619 against the 5VDC post.
Old Jun 10, 2013 | 11:32 PM
cgantner5150
Here is the info from my FSM (86). Yours should be similar. Follow the troubleshooting tree.
Old Jun 11, 2013 | 03:26 AM
Cliff Harris
The classic way to back probe a connector is with a straightened paper clip. I prefer a hat pin or needle because they have pointed tips. You need to slide the needle into the connector from the wire side. You need to work it around a bit (it tends to get hung up on things inside the connector shell) to get it to go in far enough to make a connection with the terminal in the connector shell. Then you can measure things while the connector is plugged in.
Or get one of these guys (this is what I use):
Old Jun 11, 2013 | 08:11 AM
wedgeheaded
That is WAY better than what I had rigged up. Where did you get it?
Old Jun 11, 2013 | 08:14 AM
aklim's Avatar
aklim
http://www.corvettepartsworldwide.co...ness_s/516.htm
Old Jun 11, 2013 | 08:47 AM
wedgeheaded
It's a shame they didn't use the same harness for all the sensors. A set up like that would be great for general trouble shooting.
Old Jun 11, 2013 | 09:55 AM
cgantner5150
Datalogging onto the laptop shows you the sensor readings real time and records. Definately useful for troubleshooting.
Old Jun 11, 2013 | 10:04 AM
aklim's Avatar
aklim
Find it more usefil to see ehat the ECM sees. That way you can tap the harness if necessary.
To IAC question
