Venting
Old Jun 14, 2013 | 12:26 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Venting
What kind of @#!$*&^*###! designed the combo A/C water pump mount with bolts that are so hard to access?
I will let the PB Blaster work its magic over night and hit it again in the morning.
I decided to change the water pump since I am in there anyway and now am thinking I might have been better off leaving the old one on.
I am in the process of changing the TPI over to an LT1 intake and installing under drive pulleys and an air pump delete. New lower radiator hose too.
And, gaaaaack! What a greasy, nasty, dirty area to work in. Gonna roll her out in the driveway and hit it with some degreaser and a power wash when I get it apart.
My "fun in the garage" is turning into a "why the freak didn't I buy a C6 that only requires waxing, fueling and making payments"?
There. I feel much better.
Old Jun 14, 2013 | 06:54 AM
WW7's Avatar
WW7
Come on Ron, you can do it, and when your done you'll feel much better having done a good job.....
How's that for positive reinforcement?........WW
Old Jun 14, 2013 | 10:23 AM
corvetteronw
Cruise-In VIII
This is the offending bolt/bracket. You can see where the belt tensioner attaches at the lower end of the bracket.
Gotta work on basement repair today (Spring flood). Don't have much time for the garage today
Thanks for the encouragement
Old Jun 15, 2013 | 12:23 AM
corvetteronw
Cruise-In VIII
I discovered that the nut that I was reefing on with the box end wrench in the picture is welded to the bracket. Guess I should have looked at my FSM a bit closer (embarrassed).
I sprayed this nasty/funky/filthy area down with some orange degreaser I got from Auto Zone. I will let it soak good and then hit it with a gas powered power washer that I can borrow in a few days.
Before pic for now and I will get an after pic when all cleaned up.
I'm not feeling the love with these rubber fuel lines that connect between the hard lines. Is this even safe after 22 years?
Old Jun 15, 2013 | 01:08 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
With the gas powered, power washer, you don't even need the soap. The power washer will clean that thing. It'll look brand new.
Old Jun 15, 2013 | 07:10 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
HEY WAIT, a clean car is a happy car. clean it, and you will see how much easier it is to work on when it gets happy
Old Jun 16, 2013 | 01:39 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
...and installing under drive pulleys ...
I suggest the March cast Al pulleys. I used their under drive crank & over drive alt pulleys but didn't see any HP gain. I"m thinking the lower rotational mass of cast Al might just show some power increase.
Old Jun 16, 2013 | 02:04 AM
hemivett's Avatar
hemivett
Sometimes I take things apart just to clean, paint, and polish them. Take your time, and do it right, you'll be a lot happier when you lift your hood. h
Old Jun 17, 2013 | 07:53 AM
blackozvet's Avatar
blackozvet
these cars are just pure evil !!
To Venting
