8" damper "91" Vette???
Old Jun 14, 2013 | 04:26 AM
The Bus's Avatar
The Bus
Default 8" damper "91" Vette???
Will a 8" damper clear the crossmember on a "91" corvette??
Old Jun 14, 2013 | 04:08 PM
RWDsmoke's Avatar
RWDsmoke
The motor I installed in my 86 had an 8" on it and it hit the crossmember. I thought about modifying the crossmember, wouldn't take much but it was easier to change the damper.
Old Jun 14, 2013 | 05:32 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I am in the process of doing some work on my 91 and have the front of the engine somewhat apart. There is not much room between the damper and the crossmember. I will measure the stock one and get back with you in a bit. I will try to get a pic too.
Old Jun 14, 2013 | 05:56 PM
corvetteronw
Cruise-In VIII
It appears that my 91 L98's stock damper is 7" in diameter. This pic shows the measurement from the crossmember to the top of the damper. Looks like there is not enough room for an 8" diameter damper to fit without raising the front of the engine by some means.
Old Jun 14, 2013 | 05:58 PM
The Bus's Avatar
The Bus
Thanks guys I'll go with a 7".
To 8" damper "91" Vette???
