Does an 86 require a specific thermostat
Old Jun 18, 2013 | 04:41 AM
Lucky86's Avatar
Lucky86
Default Does an 86 require a specific thermostat
I was going to use an off the shelf 180 from napa, do i need anything special for an 86? Thanks
Old Jun 18, 2013 | 08:36 AM
c4cruiser's Avatar
c4cruiser
As long as they provide the correct part number for the year, that will work fine.
Old Jun 18, 2013 | 09:10 AM
pmihaltian's Avatar
pmihaltian
Slingshot
The OEM part was a 190 degree thermostat. When you install your new thermostat, be sure to drill the holes to help with properly burping your cooling system. See attached.
Old Jun 18, 2013 | 12:52 PM
Lucky86's Avatar
Lucky86
Thanks fellas
To Does an 86 require a specific thermostat
