There's got to be a way
Old Jun 18, 2013 | 09:21 PM
Diverguy's Avatar
Diverguy
3rd Gear
Default There's got to be a way
Hello, I have a 1992 c4 and I have the all famous broken wiper switch pivot, I'm thinking instead of a massive repair,I'm thinking of a way to re attach a fabricated piece and drilling 2 holes and using roll pins,my turn signal won't click in on a right turn, any thoughts or ideas? I'm trying to think out of the box, so before you chastise me !!! Any thoughts would be great
Old Jun 18, 2013 | 10:06 PM
black-93-coupe's Avatar
black-93-coupe
I replaced the wiper/turn signal switch in my 93. Got the part from Corvette Central for around $70. Took about 4 hours to put it in. Not too bad of a job compared to other things I've done on my car (brake booster anyone).
Old Jun 18, 2013 | 10:22 PM
Impala Balko's Avatar
Impala Balko
it sounds like your tilt column needs rebuilding... I would do it before its too far gone
Old Jun 18, 2013 | 10:30 PM
Diverguy's Avatar
Diverguy
3rd Gear
Default Brake booster
I did replace the brake booster on my sons 94 vette, it actually wasn't a bad job, I removed the master, the 2 bolts, then under the dash to the clip on the shaft to it and wiggled it out, about 1.5 hrs
Old Jun 18, 2013 | 10:32 PM
Diverguy's Avatar
Diverguy
3rd Gear
Default Rebuild column
I will take the advise and just get it rebuilt, it is a worthwhile investment, thank you
To There's got to be a way
