Shaving Iron Heads?
Old Jun 19, 2013 | 01:31 AM
DanielRicany's Avatar
DanielRicany
Default Shaving Iron Heads?
Hey guys, I was just thinking about if I ever had to replace a head gasket or pull pistons, which would require a head gasket change, since my 1985 has iron heads, do I have to send them out to be shaved? Or can I just scrape them off with a razor or use a cookie? I'm used to working on cars with aluminum heads so this has never crossed my mind before. Since the main reason why we shave heads is because aluminum warps, but iron has a higher resistance to that so I'm thinking they wouldn't need to be shaved. Thanks!
Old Jun 19, 2013 | 02:03 AM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default self test
Use the old iron flat bar wrapped in emery cloth. A few swipes of that and you'll have pretty good idea of what you have.
Old Jun 19, 2013 | 06:20 AM
RichS's Avatar
RichS
Iron heads still need to be cleaned up with a resurface if needed. I wouldn't use a Cookie on it. Too aggressive and you can make the surface worse.
Old Jun 19, 2013 | 09:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
Those things cause more harm than good and can remove metal easily. Plastic gasket scrapers are nice ; quick surface done check for cracks, go from there.
Old Jun 19, 2013 | 10:09 AM
AQUILA163's Avatar
AQUILA163
We machine heads when they are warped or we want to reduce chamber volume. Put a straight edge on it after it is clean. If it's flat put it back on as is.
Old Jun 19, 2013 | 10:17 AM
WW7's Avatar
WW7
All heads should be checked for flatness no matter if iron or aluminum..Like mentioned above , a straight edge will work.....WW
To Shaving Iron Heads?
