Caliper sticking
Old Jun 20, 2013 | 03:36 PM
camhudson's Avatar
camhudson
Default Caliper sticking
I have a 1989 c4 coupe. The left front caliper won't release (is sticking) when I release the break pedal ( I discovered this problem when I noticed the wheel was hot). I replaced the caliper with a new one but it didn't solve the problem. Does anyone have any idea what is causing the problem?
Thanks,
Cam
Old Jun 20, 2013 | 03:40 PM
94z07fx3's Avatar
94z07fx3
Sounds like the rubber line from the hard line at the chassis to the caliper has failed internally and is blocking flow back to the master.
Old Jun 20, 2013 | 05:20 PM
leesvet's Avatar
leesvet
yep.
the hose is acting like a check valve.
Old Jun 20, 2013 | 05:42 PM
camhudson's Avatar
camhudson
Thanks for your answers. I was hoping that was my problem.
Old Jun 24, 2013 | 11:58 AM
camhudson's Avatar
camhudson
I installed a new caliper and a new rubber hose (line) and my caliper is still not releasing (still sticking). What else could it be?
Old Jun 24, 2013 | 12:22 PM
GKK's Avatar
GKK
When you bled the lines, did brake fluid flow out easily?...
If not, contamination in the lines is blocking the fluid flow somewhere.
Also, check that the new caliper functions properly by disconnecting the brake hose and blowing compressed air into it.
Old Jun 24, 2013 | 12:32 PM
davewhtt's Avatar
davewhtt
If the lines are going bad you will be getting rubber bits and parts in the system. Change the fluid. Was it a new caliper or rebuilt? Make sure you didnt kink/twist the new line.
Old Jun 24, 2013 | 05:26 PM
camhudson's Avatar
camhudson
[QUOTE=davewhtt;1584234220]If the lines are going bad you will be getting rubber bits and parts in the system. Change the fluid. Was it a new caliper or rebuilt? Make sure you didnt kink/twist the new line.[/
It is a new (after market) caliper. I will change the fluid. Thanks for the help.
Old Jun 24, 2013 | 05:52 PM
yorkfitter's Avatar
yorkfitter
Had the same problem and it was the ABS pump, ended up tearing it out.
Old Jun 25, 2013 | 06:19 PM
cmontel727's Avatar
cmontel727
Had the same problem with my 87, used abs pump off fleabay solved the problem
To Caliper sticking
