Ball joint problem
Old Jun 21, 2013 | 07:15 PM
Hotwheels87mi's Avatar
Hotwheels87mi
3rd Gear
Default Ball joint problem
I have a 1987 and the ball joints are lose. The mechanic want to heat the alum lower control arm to get the ball joint to fit. Does this sound correct?
Old Jun 21, 2013 | 07:18 PM
ex-x-fire's Avatar
ex-x-fire
No, does he have a ball joint press?
Old Jun 21, 2013 | 07:24 PM
Hotwheels87mi
3rd Gear
Yes he says it will not fit.
Old Jun 21, 2013 | 08:06 PM
ex-x-fire's Avatar
ex-x-fire
I'm missing something here, what doesn't fit? The BJ press is like a c clamp that has adaptors for removing & installing the BJ. Google "ball joint press" to see what they look like.
Old Jun 21, 2013 | 08:35 PM
Hotwheels87mi
3rd Gear
Default Main point
[QUOTE=ex-x-fire;1584215741]I'm missing something here, what doesn't fit? The BJ press is like a c clamp that has adaptors for removing & installing the BJ. Google "ball joint press" to see what they look like.[/QUOTE the
The mechanic stated that he was having trouble with the ball joint fitting in the control arm. He ordered ball joint from two different manufacture. They would not install as normal press. He want to heat the aluminum arm up and cool the ball Joint in when he gets it in. I don't think this correct.
But I have not done this type of work. What would you recommend?
Old Jun 21, 2013 | 08:47 PM
Purple92's Avatar
Purple92
I would NOT recommend heating the aluminum control arms !!!
I've done the ball joints on my 92, and while I don't think the control arms are the same, I do believe they are quite similar. I had a problem pressing mine out of the lower arms - so I took the lower control arms to a local automotive machine shop - where they used a large hyraulic press to push the old ball joints out and the new ones in. The key is to have the right adapters to use with the press.
Old Jun 21, 2013 | 09:38 PM
Cheechsmith's Avatar
Cheechsmith
Do not heat the control arm. It sounds like he may have purchased a
problem solver type ball joint. They are slightly oversized for control arms that are slightly damaged and will no longer hold a normal ball joint tight.
If your control arms are not damaged they will be if you force these in.
http://www.oreillyauto.com/site/c/de...%26+components
Old Jun 21, 2013 | 09:39 PM
ex-x-fire's Avatar
ex-x-fire
Take a micrometer & measure the new & old BJs.
Old Jun 21, 2013 | 10:56 PM
JackDidley's Avatar
JackDidley
Ive seen lots of threads saying aftermarket joints are too big. Especially cheap ones.
Old Jun 22, 2013 | 10:25 AM
Streamline's Avatar
Streamline
Yes, been there done that....Even the Moog that I tried were oversized. The best fitting ones I found were Raybestos. I put the ball joints in the freezer which helped but still was a battle getting them in.
Old Jun 22, 2013 | 06:07 PM
mtwoolford's Avatar
mtwoolford
MOOG ball joints have been reported to fit properly
Old Jun 22, 2013 | 08:04 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
DO...NOT...HEAT...ALUMINUM!!! got my moog ball joints from summit, also the sleeves for pressing them out and installing them using a hydraulic press. worked perfectly.
To Ball joint problem
