Went to start the car this morning and it cranks but will not start. Checked spark and I have nothing! I have power to the coil and ignition module. The Optispark unit is < 1 yr old. HELP
Well I checked codes. Nothing. Went through voltage checks and all looked good. Checked harness going to distributor, all good. Re-seated the distributor plug at the mainfild and it started. Now Im confused. Possible bad plug conection?
Drove it for a few miles and it shut off once started right back up.
Now Im scared it is going to leave me stranded!!
I did intake gaskets last week and I think maybe I did not plug the distributor line back tight?
Swapped ICM (Ignition Control Module) and coil again. Still intermittant spark. Could the PCM/ECM be crapping out? Suggestions on where to get one or do I have to get mine rebuilt?
