Fuel Issue
Old Jun 23, 2013 | 08:33 PM
gary096's Avatar
gary096
3rd Gear
Default Fuel Issue
Sometimes my 96 Vette wont start, but then if I loosen or take the fuel cap off, it starts right up. Is this a sign of the fuel pump going out?
Old Jun 24, 2013 | 04:46 AM
JMelton's Avatar
JMelton
When you take the cap off, can you hear a big inrush of air when this happens?
You might try cleaning the cap, or replacing it. The vent could be plugged up.
Old Jun 24, 2013 | 12:17 PM
davewhtt's Avatar
davewhtt
Old Jun 24, 2013 | 12:42 PM
bac22's Avatar
bac22
Fuel pump is a likely suspect, but do the basics first like changing the fuel filter. If the cap was bad I would suspect you'd have a check engine light on. How is your fuel milage? Have you noticed a drastic change? Also see if you ECM is holding codes.
To Fuel Issue
