We're working on a 85 with a 434 that dyno'd 700 hp with a carb. With a modified Stealthram, 48 lb Accels, and a 1227730 ecm the car would run good until it got warm, and then it would start sputtering. The AC Delco rep has said we're burning up injector drivers. We've burned up 2 ecm's.
Got pissed off, put a carb on it and ran 9.97 at Bremerton, WA on street tires. Okay, in the meantime, injectors went to Dr. Injector and it seems one is short to ground when opened. Would this bad injector be the cause of driver failure, or is 700 hp overwhelming the OEM speed density system overheating the injector driver?
Any common sense input will be appreciated.
I've seen folk run bigger injectors with the HP on the 730 no problem, so can't see where that could be an issue. Just curious what bin your using? 8D s_aujp?
(8) 48 lb./hr injectors at 100% duty cycle should flow `384 lb/hr. of fuel. Assuming 0.5 bsfc this could support ~ 76h8 hp which is in the ball park.
It would seem that bigger injectors are in order to avoid 100% injector duty cycle and burning out the drivers. (8) 63 lb. injectors at ~76% duty should live at this hp level. Needs more injector assuming fuel pump can keep up.
AXCN was the base file used. No need for S_AUJP, because the motor has 15" of vacuum at idle. Can you say REALLY BIG HEADS and a reasonable solid roller.
Interesting suggestion? Thank you for the candid comments, they will be considered. I'm leaning towards the one bad injector being the cause, because the car hadn't really been driven hard. In one datalog (Datamaster) it went 100% TPS I saw only 40% duty cycle, so I'm thinking this bad injector was a possible cause of more problems than just heating injector drivers.
Even 100% duty cycle, especially since it should be for a very short duration, shouldn't fry a computer. Shorted injector definitely could, so first get that fixed. After that you should be good to go.
BTW: was the same bank always failing? Presumably it was the bank that also had the bad injector.
I am an electronic engineer and about 5 years ago I saw an ad in one of the electronic design magazines for new injector drivers. Unfortunately I somehow lost the info and don't even remember which manufacturer it was. I think it was IR (International Rectifier).
More dumbness on my part: I took my ECM apart and wrote down the part number for the injector driver. I lost THAT too (actually all this info was lost in a computer crash but I didn't have this particular bit of info backed up). I do remember that it was made by IR, who makes a LOT of MOSFETs, which is what the injector driver is.
Anyhow, the point of this post is that later versions of these transistors are much more robust than the antiques in the original ECMs.
Reason: Clarification.
My recollection is that Digi-Key carries these parts. Our ECMs use the TO-220 package and need a low RDS(on). RDS means Resistance from Drain to Source and basically tells you how hot the transistor will get when it's turned on. The lower the better. You're only going to pull about 10 amps, so any one of those will work fine. It is important to get a good thermal connection to the ECM heat sink to help the transistor stay cool (that's relative because it will get pretty hot to your touch, but not hot enough to hurt itself). I have seen transistors that got so hot they melted the solder that held them into the PC board but they were still working. That's why GM was able to put the ECMs under the hood of the later C4s.
