Is it worth the effort?
EDIT: It's of course a 350, simply an oversight. Forgive me, it's late. Thanks however.
.......WW.
These cars are generally not investments, but rather expenses.....good luck
I'm 24, getting married and just not sure I have the cash. I'm a novice mechanic at best, but have access to the best help and tools should I Need it. and I will. OH lord I will.
It seems that way though, just because you don't see too many people trying to save any other 30 year old car.
You would have all of these exact same issues with any other car the same age.
Lots of people buy one of these cars "cheap" telling themselves what a good deal they got and that it only needs a little bit of fixing up.
Truth is, in most cases your money ahead to spend a little more and buy one that is in excellent condition.
If you want to restore it and have everything perfect, it is huge money pit.
If you want an inexpensive driver and can put up with a few problems, then it can be an inexpensive car.
I have had both kinds.
My inexpensive ones were an '88 A4 and a '94 M6. I bought them pretty cheap to use as daily drivers. In about 5 years I put about 100k miles on them. When I sold the '88 after 2.5 years I got about what I paid for it. The biggest repair I did was an EGR valve that cost about $50. When I sold the '94 after 2.5 years I got within $300 of what I paid for it. I did a couple of repairs such as the rear wheel bearings/hub, a half shaft u-joint, a used seat bottom, and muffler eliminators. On both cars there were little things like a new radiator cap, a repaired shifter ****, normal oil changes and spark plugs, etc. On both cars the key was finding something fairly decent but needing a few things that I could buy at a decent price.
On both cars there were things that were not right, but I could live with them. For example the radio antenna would not go down all the way, the cd player didn't work, the headlamps made some extra noise when going up or down but still worked, there had been some body work that I would have liked to fix right (but from 10 ft it looked pretty good). I would have liked to do a new interior, but the worn interior didn't look too bad. The weather strip leaked, but was able to stop the leak with some RTV.
To keep them running they are similar to many other cars (small block motors, auto transmissions, starters, alternators, brakes, shocks, etc.)
For me these were two of the least expensive cars I have owned (out of about 70 or 80 cars) and the most fun. I could drive them on my 100 mile per day commute because of the good mileage, and the handling/performance made them fun.
The C4 is getting to be an exception because of the resale values and numbers manufactured. FI is also more reliable -- so we're seeing more (still) on the road.
If you'd be happy driving one...and keeping one running -- at the lowest cost possible, they aren't the worst choice for a single guy/gal. Once you talk marriage and a family, ANYTHING that's old and "iffy" condition should be considered a risk. It MAY run and serve you well, but -- at 30 yrs old -- there are a plethora of age-related problems that can/will pop up at any given time.
I think you should sell it, start that family, then revisit the prospect at a later time in your life. Marriage/family are not worth risking on an iffy (old) sportscar.
My biggest clue is that you're ranting on a BATTERY...which is a very minor problem. It shows the lack of resources you must have.
.......WW.
The way I look at it is like this.
My corvette Is not an investment or a Vehicle for that matter. It's my hobby. I could spend my money playing golf, shooting skeet, rafting, on hookers, on blow, yelling at a team on the TV set while at a bar drinking expensive beer because I placed a bet on them...or my car.
I think i'll spend it on something that won't give me a disease/kill me and I can enjoy on nice sunny days.
This....
This....
To the original poster: Whenever you buya used car, you find at least a few items that you need to fix, because the previous owner stopped fixing things properly once he decided he was going to sell sometime soon. But, it IS always good to buy the very best condition car you can afford, as yes, it IS cheaper that way, despite the initially higher price.
About a month ago, I bought a 1992 Corvette convertible with just 9400 miles on it (the Carfax was an intriguing read - 300 to 400 miles per year documented). I paid a premium price for it because of its low miles and fantastic overall condition, and because it is intended to be my daily driver coming-soon-retirement car. I wanted a 1992 through 1996 model, as I had a very happy 2.5 year experience with a 1995 model back in the late 1990s.
In just under a month, I have put on close to 1500 miles, and the only 2 issues I've had were a need to get the driver side window adjusted a bit for a betetr fit on the weatherseal, and replacement of the wiper motor cover because the wipers would turn on and run normally but would not shut off unless I shut off the ignition. These sort of problems are normal on a used car you just bought. But, note that these have been the ONLY problems, because the car I bought had low miles and had been properly preserved. Worth the extra money.
That said, I am pouring a few hundred dollars into fluid changes: brake fluid, engine coolant, engine oil, rear axle fluid, and automatic transmisison fluid. All are being changed, and all are going to synthetic - the best I can buy - as I view these as preventative maintenance. This is part of buying and commissioning any worthwhile used car that you intend to KEEP as more than a short-term daily driver. THis prevents costly on-the-road emergencies later on. If you cannot afford to spend the money to do stuffkike this, you shouldn't buy a 20 or 30 year old car, and especially not a Corvette.
And, to answer your underlying question: YES, it is definitely worth the effort. I rememebred that 1995 model as being my favorite ever car, including even a better fit for my tastes than the 2002 Z02 I bought brand new in 2002. This 1992 model is reproducing the magic successfully.
Jim G
) i bought my 91convertible. i think that you will regret selling it if u do. I dont know your finances but if u can afford to keep it, and its paid for, i think you would be better off keeping and fixing a little at a time rather than get into something you will hate!
....WW
