Most of the frame is bonded to the body. Replacement bushings are usually for the Suspension on a C4. There are replacement bat wing bushings...
Main problem is c4 replacement bushings are poly urethane. If you want rubber you have to buy the entire upper/lower a arms and new dog bones
If you really want a better ride/handling quality skip the poly rears and go for a spherical rod end suspension kit.
