Need to replace lower front ball joints, what else while there?
Anyway, I do race my car every few weekends and it is also my daily driver. While the lower ball joints are being replaced, should I also do poly bushings or anything else that's down there? The car has 120k miles and everything is original. Maybe it's time for new shocks too?
Any advice is appreciated thank you!!
If you do poly put some VBP off set lower control arm bushings in the front. Keep in mind poly will bump you a class in most organizations.
Keep in mind the front hubs could be at fault. Make sure you know what is moving before just blindly replacing parts.
http://www.corvetterecycling.com/198...trolarmkit.htm
http://www.corvetterecycling.com/category_s/90.htm
