Headlight/Digital Display Dimming Problems
Old Jun 26, 2002 | 05:30 AM
TIMSPEED's Avatar
TIMSPEED
Default Headlight/Digital Display Dimming Problems
As many of you know, I've been having trouble with my Headlight Actuator Relays...well, ANOTHER one blew, and now, when I turn on my lights, the dash lights go out (instead of dimming) I also noticed that my CLUSTER fuse was blown (I think it was cluster..it was on bottom, a 3amp fuse) So I replaced it and turned the lights on and it blew. What's going on here? I was looking at the wiring diagram and it doesn't show the headlight's going to that fuse AT ALL. Is it possible that having a broken relay on one side is doing this? I'm ordering brand new left/right relays as well as the isolation relay 2moro. This problem is getting annoying! Please Help! TIA!
Old Jun 26, 2002 | 01:24 PM
jfb's Avatar
jfb
Default Re: Headlight/Digital Display Dimming Problems (TIMSPEED)
You have a short in your cluster or other dash lights. I'll look at my schematic when I get home for all the circuits the 3A cluster fuse powers. I don't think your headlight relay is related.
Old Jun 26, 2002 | 07:11 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Headlight/Digital Display Dimming Problems (jfb)
But it only pops when the headlights are turned on. I also noticed that when I put a higher amp fuse in the CLUSTER spot...the TAIL fuse blew. (so Could it possibly be the fog/parking lights blowing the fuse) This is REALLY annoying!
To Headlight/Digital Display Dimming Problems
