92 LT1 specs please
Old Jun 27, 2013 | 08:58 PM
ruizsand1's Avatar
ruizsand1
Default 92 LT1 specs please
Can anyone help in filling the empty fields?
Thanks in avance!!!
Make: Chevrolet
Year: 1992
Model: Corvette convertible
Weight:
Transmission Type: Manual 6 speed
Axle Ratio:
Engine Block Type: Chevrolet
Engine Size: 350 c.i.
Engine Family: LT1
Number of Cylinders: 8
Bore:
Stroke:
Compression Ratio:
Connecting Rod Length:
Exhaust Valve Size:
Intake Valve Size:
Intake port air flow volume
Exhaust port air flow volume
Intake Manifold Type:
Fuel injection Type
Head Runner Volume:
Rocker Arm Ratio
Rocker Arm Type:
Rocker arms stud size
Lifters type
Push rods size
Springs type
Springs lbs.
Camshaft Brand: Original stock
Camshaft lift:
Camshaft duration:
Camshaft Overlap:
Throttle body diameter
Speed Density Sensor:
Oil pump type
Oil pump capacity
Old Jun 27, 2013 | 09:17 PM
vetteoz's Avatar
vetteoz
http://www.motorera.com/corvette/1990/vet92.htm
Originally Posted by ruizsand1
Bore: 4.00
Stroke: 3.48
Compression Ratio:
Connecting Rod Length: 5.70
Exhaust Valve Size:
Intake Valve Size:
Intake Manifold Type: EFI
Fuel injection Type
Head Runner Volume:
Rocker Arm Ratio 1.5
Rocker Arm Type: SA
Rocker arms stud size 3/8"
Lifters type roller
Push rods size 7.200
Camshaft lift: .450
Camshaft duration: 205/207
Throttle body diameter 48MM
Old Jun 28, 2013 | 04:24 PM
ruizsand1's Avatar
ruizsand1
Default Some more fields missing
Thanks VetteOZ
Anyone for the rest of the info?
Compression Ratio:
Exhaust Valve Size:
Intake Valve Size:
Intake port air flow volume:
Exhaust port air flow volume:
Head Runner Volume:
Springs type:
Springs lbs.:
Camshaft Overlap:
Oil pump type:
Oil pump capacity:
To 92 LT1 specs please
