O2 sensor broke..
Jun 29, 2013 | 08:34 PM
O2 sensor broke..
I have a Bosch O2 sensor standing by to replace the one that's just hanging down by it's wire.
What I see on the exhaust is a round hole, with a hex bolt
Do I assume correctly that what is left in the pipe is the body of the old sensor, and I need to crank on the hex to get her out?
Thanks,
Rich
ps. sorry for no pic!
Jun 29, 2013 | 09:27 PM
If access to the O2 hex is limited, this socket works really well:
If access is not a problem, you can use the deep wall socket:
Check for the correct socket size..... my '92 needed 7/8 ..... sensors came with anti-seize applied.
Caution: keep the sensor tip clean.
Jun 29, 2013 | 09:37 PM
OK SWEET
ACCESS ISNT TOO BAD, i'LL GIVE HER A WHIRL(AFTER PLENTY OF PB BLASTER..)
\RICH
Jun 29, 2013 | 09:41 PM
Quote:
Originally Posted by
celticpiping
OK SWEET
\RICH
PB may not be necessary, but can't hurt. Just changed my originals on my '92 without even a breaker bar.
You won't need the deep socket to remove the broken sensor, but you will to install the new sensor.
Jun 29, 2013 | 09:57 PM
A little heat will make the old one come out easy. I usually run the car for 2 or 3 minutes.
Jun 29, 2013 | 10:58 PM
I use the box end of a combination wrench. Just thread the connector and wire through the box and go at it.
Jun 29, 2013 | 11:07 PM
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
A 7/8" will do
Jun 30, 2013 | 01:26 PM
You guys are awesome. Thanks much for the feedback
