450 engine build
Old Jul 2, 2013 | 09:49 AM
tpi 421 vette's Avatar
tpi 421 vette
Default 450 engine build
Hey Guys, I am freshening up my 450 (4.165x4.125). The pistons had some wear, but the cylinders only had .001 wear, so I kept the 4.165 bore and got new pistons. So I will have one more build in it at 4.185. It got a real light hone and new crank, rings and bearings, timing chain ect. I reused alot of the parts that were real good like cam, lifters, AFR 245's and Crower billet rods. They were like brand new. You can see some major clearancing in the Bowtie block for the 4.125 stroke. The block has a low fill, it would have hit water to make it clear. But everything is coming together nicely.
The cam is a Crane 252/260 .714/.674 on a 112 LSA solid roller
I degreed the cam and it was 1 degree advanced. So I left the cam timing there.
Old Jul 2, 2013 | 10:18 AM
383vett's Avatar
383vett
Looks good Jim. Ready to fire up on the 4th?
Old Jul 2, 2013 | 10:41 AM
93 lt1 vette's Avatar
93 lt1 vette
Wow, just wow. Very impressive setup. I've got a few questions. Are you running any block fill? "low fill" Static compression ratio? Any work to the AFR heads? or out of the box?
Old Jul 2, 2013 | 10:53 AM
tpi 421 vette
It has a low fill of block filler. Compression is 12.25, it will run on pump gas up here with that compression. And the AFR 245's are out of the box.
And Willie, I don't think it will be running by July 4th. But it should be running soon!
Old Jul 2, 2013 | 11:42 AM
ch@0s's Avatar
ch@0s
Cool, thanks for sharing. I love to see naked enguns.
Old Jul 2, 2013 | 12:17 PM
cumbercr's Avatar
cumbercr
Amazing how Jim makes this look so easy. I'm proud to have one of his engines in my car.
Old Jul 2, 2013 | 01:58 PM
383vett's Avatar
383vett
You've got a real problem.
Old Jul 2, 2013 | 02:01 PM
ch@0s's Avatar
ch@0s
I know, I need counseling.
Old Jul 2, 2013 | 02:13 PM
1985 Corvette's Avatar
1985 Corvette
Yeah, I'm still working on that one. I think I have busted the record for Jim's slowest, smallest CID build by the most broke *** CF member, by far for his builds. That cam looks alien after staring at so many street friendly hydraulic cams.
Old Jul 2, 2013 | 02:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
Not really, J. Built my 383 from leftovers mostly
Pretty impressive motor there Jim, you gonna cap it off with a TPI Torque Monster intake?
Old Jul 2, 2013 | 02:47 PM
Matatk's Avatar
Matatk
I am intrigued by these big cube small blocks!
Is it common for the piston to wear faster than the cylinder walls?
What was the reason for the tear down? How long since the last build?
Old Jul 2, 2013 | 02:59 PM
tpi 421 vette
I think with a stock tpi on a 450CI engine it wouldn't go over 2000rpm Actually it's getting the ported Miniram by Tony Mamo back on it (Mamoram) All of the ports flow between 400-410cfm. And a Monoblade T.B.
Old Jul 2, 2013 | 03:07 PM
tpi 421 vette
I went thru it mainly because it had a issue with the crank and damper from an old machine shop I used that honed the damper too loose, and made a mess out of the crank. With a 4.125 stroke, a 5.85 rod, the geometry isn't good. But I knew that going into it. I got 7 years of use out of it. They tend to wear pistons with all of the sideloading going on. The 200 shot of nitrous helps the wear along in it also. When you build this big of a SBC, you are trading long term durability for cubic inches and potential power. It's not for everybody, but it works for me.
Old Jul 2, 2013 | 10:40 PM
tpi 421 vette
Well Guys, it's completely assembled ready to go back in the car. I just need to take it off the stand and put the flywheel and McLeod dual disc on it. It should be running soon.
Old Jul 2, 2013 | 10:48 PM
383vett's Avatar
383vett
Come on Jim. Bolt on a torque converter.
Old Jul 2, 2013 | 11:29 PM
tpi 421 vette
It would probably be quicker with a 4000 stall and a trans brake. But it's fun banging gears with the ZF
Old Jul 2, 2013 | 11:33 PM
thetoy's Avatar
thetoy
Looks great!! You did no upgrades at all? If so you are a better man than I. If I spend the time to pull it out I can't help myself from wanting just a little bit more.
To 450 engine build
Old Jul 2, 2013 | 11:38 PM
tpi 421 vette
I just put the AFR 245's on it not too long ago with the Crower shaft system. I haven't run it at the track since doing those upgrades. So it's a new engine combo I haven't really tried out yet. Everything is now fresh and new.
Old Jul 2, 2013 | 11:58 PM
mrmmoore's Avatar
mrmmoore
You have to make a video of that beast when you're ready to fire it up.
Old Jul 3, 2013 | 12:01 AM
88BlackZ-51's Avatar
88BlackZ-51
Say that intake looks awful familiar!!
Cant say enough good things about Jim.
Lets get it all buttoned up, and get that sucker into the 10.0x.
