it wont go!!!
Old Jun 26, 2002 | 03:27 PM
joe underwood 3's Avatar
joe underwood 3
Default it wont go!!!
have put th e369 solid roller back together in the 93 6-speed car. the problem is that the computer seems to hit a rev limiter like wall at around 7200. its not a spring concern, flost, etc. the rev limiter has been moved in th ecompter to 10k, but there is something keeping this darn thing from going upstairs. any help appreciated. thansk, joe.
Old Jun 26, 2002 | 05:24 PM
SpedRacr93's Avatar
SpedRacr93
Default Re: it wont go!!! (joe underwood 3)
If you don't think its float, how about lifter pump up or ignition problems.
10K huh? Is this a drag car?
Old Jun 26, 2002 | 08:20 PM
95vettski's Avatar
95vettski
Your only option is to swap to an aftermarket engine management like a fel pro, motec etc. The camaro LT1 pcms reads only to 7000 rpms, the vette is able to hit 7200! Must be a big solid roller, where does peak hp occur?
Hope this helps.
:cheers:
To it wont go!!!
