rearend issue, help.
Old Jul 6, 2013 | 10:29 PM
ghoastrider1's Avatar
ghoastrider1
Default rearend issue, help.
saw an answer to this months ago, but cant find it. I nailed the vette the other day and heard a thump come from the rearend. Seems like the posi isn't really working now, but not sure. Just doesn't seem right. Where to look first? Thanks.
Old Jul 6, 2013 | 10:34 PM
leesvet's Avatar
leesvet
pull some fluid and take a close look for metal. Otherwise, drain and refill with GM posi-additive and the proper wt grease.
A clunk/clank can be a joint also..
Old Jul 7, 2013 | 07:07 AM
ghoastrider1
thanks. Its not the sound a u-joint makes. Sounds more like something larger broke.
Old Jul 7, 2013 | 10:34 AM
leesvet's Avatar
leesvet
ouch...
then I'd pull some lube out and strain it thru a white cloth and look for metal...
Old Jul 7, 2013 | 01:30 PM
radar502's Avatar
radar502
This is not a Add. for the Purple stuff ..This is what I did helped ..Drained oil ,put in Royal Purple gear oil,then went right around then left around a few times .Mine stoped makeing a sound.. Very messy job and not cheap ..Just saying worked for me...
To rearend issue, help.
