PCM? problems...
. After the car started to buck occasionally, I turned around and parked it. I noticed the check engine light was on, the service ASR light too. The sys and security lights flashed 3 times in sync. My speedometer wouldn't pick up my speed either, it just said 0.I pulled several codes.
1. C41 H41 H72 H74
4. ERR
9. H72
I'm kinda thinking that maybe there is something loose, but I am not sure. The other thing I have noticed while under the dash was a toggle switch someone mounted. It goes to the mounting bolt to the pcm, to some relays next to the fans. Not sure what this is supposed to do, but I would like to remove this soon if it is not needed.
Ill look tomorrow for something loose at the pcm, but other than that, I am not sure. Any help would be great.
http://chevythunder.com/199295_lt1_trouble_codes.htm
Also, is the toggle part of the code 41 issue?
So 1. C41 is ECM data communications lost. H41...same... H72 LCD dimming open H74 LED display open 4. Err.... can't communicate with mod? 9. H72 serial data link error.
I would seriously think something came unplugged, I just don't know where to look. I tried pushing on the ECM plugs (4 of them ), but that had no effect.
Any idea on where the "ECM data communications" is? Or even the "serial data link" ?
Also, I started it up and let it run a little after/while tapping on the ecm and random stuff. nothing. I noticed it was idling high (800, which I assume is for it being cold) , but than got higher (up to 1500). About 1200rpms, the car smoothed out, dropped to 500 rpms, all problem lights went out except ASR light. Car ran great for about 30 seconds, than lights came on, and went back to acting up. I noticed even from key on, to the point I shut off the car, the cooling fan was blowing as fast as it's little heart could.
Really confused and any help would be great.
Here's a thread you might find interesting:
http://forums.corvetteforum.com/c4-t...cm-repair.html
