After 6 years it's time to take the toy back to the strip. I'm looking at a pair of M/T ET street RADIALS. Any comments both good or bad would be greatly appreciated. I'm considering the following mounted on 11"rims.
I'm running the M/T ET street radial 2 on the ZR1 17x11, good fitment, kind of a strange shoulder (lacks the traditional rim support that protrudes out past the rim face). Otherwise, VERY sticky! Even at 32 psi tire pressure, there is a TON of grip. Very pleased with these. I'm certain I can drop the tire pressure and get maximum traction, but at this tire pressure setting, it's very drivable/streetable.
I use to run nitto NT555DR's on my old 93'. That was a harder compound and would have likely lasted a bit longer. However, the nitto's run a little "narrow" in relation to other brands.
Thanks for the info, which of the two sizes are you running. I'm leaning toward the larger diameter tire at this point.
The ET Street Radial II is offered in a 315/35-17 (26") OR a 295/45-17 (28" tall). I am running the traditional 315/35-17 on mine without any fitment issues or clearance issues.
The original design (called the street radial) only comes in a 275/40-17 (26").
Both tires offer the same compound. The "Street Radial" has that cool "slick" tread down the center of the tire. Although this is a better choice for drag racing, I wanted a little more width, and since the compound is the same, I went ahead and purchased the "Street Radial II". It has a little more "street" friendly tread pattern. I have no complaints.
The icing on the cake is that Mickey Thompson is currently offering a mail in rebate (just got mine) of $50 dollars for the purchase of two or more tires.
[QUOTE=mnstrlt1;1584351168]I'm running the M/T ET street radial 2 on the ZR1 17x11, good fitment, kind of a strange shoulder (lacks the traditional rim support that protrudes out past the rim face). Otherwise, VERY sticky! Even at 32 psi tire pressure, there is a TON of grip. Very pleased with these. I'm certain I can drop the tire pressure and get maximum traction, but at this tire pressure setting, it's very drivable/streetable.
I run the Nitto 555 street compound (not the drag radial) and the width is correct. I have heard the DR compound runs narrow but the street seems to measure as expected for a 315/35.
The nitto is the stickiest tire I hve run Compared to BFG, Goodyear, Dunlop, and Firestone.
I opted not to run a drag radial to prevent grenading my dana36, half shafts, or drive shaft. Would rather break the tires loose over breaking hard parts.
At 32psi on my M/T's the tires STILL break loose. With a traditional street tire, any spirited driving is downright dangerous. I think RVY can attest. It's like a 3400lb missle on skies. The M/T's make traction much more controlled, and you can still break them loose at will. I use to break the old tires loose rolling into the throttle. When boost kicks in, it's game over for the tires. The M/T's hook. I'm sure dropping the tire pressure and trying to drop the clutch at 4k rpm will result in broken parts, but a high horsepower combination takes some finesse to drive right.
With the stock suspension, stab this thing at 45 mph and your going sideways in traffic. Most supercharged 383LT-1s generally produce 550+ rwhp and "suffer" from this problem. I'm still looking at a Carrols rear end. But at my age I'll probably be gone by the time it arrives!
