I have a 96' LT-1 that I want to replace the O-Rings in the fuel rail. Not the injectors but the seals in the rail itself. Does anyone know where to get a kit for the rail seals or have a part number? I can't seem to find one anywhere. Does Jon at FIC sell them?
MrWillys:
Went to that site but could only find a set for injectors. The fuel rail kits only go up to 92'. What is the difference between 92' and 96'? I know the crossover pipe between the rails is in the front compared to the rear for earlier models but, are the O-Rings the same?
The parts are discontinued.
GM 17113086
Delco 217449
Advance Auto and O'riley Auto Parts show the two regulator O'rings made by BWD 274814 and 274813 for $10.00 each
Looks like they would have to be ordered.
The GM/Delco kit contained two cross over tube orings and the
the two orings for the regulator.
If you can't find the kit you'll have to measure the orings
and purchase them individually.
