'85 Rear Identifying #'s
Old Jun 26, 2002 | 10:56 PM
joseph p's Avatar
joseph p
Default '85 Rear Identifying #'s
Where are the numbers that identify the ratio, imprinted on an '85 corvette rear? It's out of the car, so I can't check the car. It was from a stick-shift car!
Old Jun 27, 2002 | 12:45 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: '85 Rear Identifying #'s (joseph p)
Post all of the STAMPED numbers off of the carrier assy. Somewhere in that mess of numbers there should be a Dana "bill of material" number. I can "decode" most of the '91 and older diffs.
Old Jun 29, 2002 | 02:23 PM
joseph p's Avatar
joseph p
Default Re: '85 Rear Identifying #'s (CFI-EFI)
Cannot find any STAMPED numbers only two sets CAST on the pumpkin????
Old Jun 29, 2002 | 03:43 PM
CFI-EFI's Avatar
CFI-EFI
Obviously, cast numbers aren't going to help determine a ratio. I can guide you to as where to find the numbers on a solid (straight) Dana axle assy, but I don't know where they are located on an ICA assembly. My guess, is that they are on a flat, machined, surface, maybe not. On a solid axle it's stamped into the axle tube. They're there. You may have to scrape and wire brush, but despite the claims of many before you, I haven't see the axle, yet, that Dana missed stamping. Good luck.
Old Jun 30, 2002 | 05:22 PM
LD85's Avatar
LD85
Dosent the info on your rear comparment door give you a code for rear end axle ratio? :confused:
:seeya
Old Jun 30, 2002 | 05:42 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: '85 Rear Identifying #'s (ld85)
Yes it does. Can't remeber but I think it is g52 or something.
Old Jul 1, 2002 | 12:02 PM
joseph p's Avatar
joseph p
Default Re: '85 Rear Identifying #'s (85WHITEZ51)
Unfortunately...cannot check cover since rear is out of car and car is long gone.
Does anybody know SPECIFICALLY where the stamped #'s would be on the rear??
Old Jul 1, 2002 | 01:07 PM
Corvette0096's Avatar
Corvette0096
Here you go.
http://www.corvetteactioncenter.com/specs/1985.html
Old Jul 2, 2002 | 12:11 PM
joseph p's Avatar
joseph p
Default Re: '85 Rear Identifying #'s (corvette0096)
OK, that tells what the number should be...but I need to know where it's located1??
To '85 Rear Identifying #'s
