people say hey its a small block chevy they are gona have a small puff of smoke after sitting. Do most 100k plus corvettes have a small puff of blue smoke. I notice sometimes when i go heavy on fuel injector cleaner in the gas i get more of a puff on start up. Any input is welcome. Thanks
A puff of blue smoke after it sets is probably worn valve stem seals, not anything in the fuel..Mine had 116,000 on it before I put in the 383 and it never smoked or puffed blue...WW
Originally Posted by 383vett
Valve guides and seals need R&R.
My 87 did it at 35k miles. Never a problem but at 85k it was a good excuse to get aftermarket heads.
doesn't hurt anything, except maybe pride.. Its a sign that seals are going to that big race track in the sky. If the smoke continues after start up..its the rings.
Blue smoke is oil
White smoke is coolant
black smoke is too much fuel (rich)
Stem seals are your most likely culprit. Not simple, but not the most difficult or expensive thing ever to fix. It's generally a good sign that you just need a top-end rebuild. Do the heads and clean/replace/scrub everything in the intake. New sensors, rebuild the distro. New gaskets are just part of the process. This will probably gain quite a bit of horsepower back as well
Even the low miles cars will do this... 86 with 20K. This engine runs great, the oil is clean and so is the coolant. Does not burn any oil. I will put up with a little smoke at start up until a head gasket goes.
My 85 did this for 20 years. I upgraded to roller rockers and did the seals at the same time. No more smoke on startup. It's actually pretty easy to do and all the instructions are right here on the forum.
Wouldnt be alarmed over a little puff not a big deal
Replace seals or just drive/live with it.
Mine started the puff of smoke at around 50K miles. I was putting off fixing it and then I got major complaints from members of my Corvette club about the smell... ;-)
Valve stem seals fixed it. Still good at 116K miles.
My 88 smoked at start up at 90,000 miles. Caused no performance problems for 30,000 miles. But in my experience if this continues, the oil may pollute your Catalytic converter. The guts of the Cat will get hard and rattle and you will have to replace it. I pulled the Heads and had them rebuilt and now no more smoke. Pulling the Heads is not easy but not impossible for the home mechanic. You will need the proper tools.
