Battery Light Illuminated
Old Jul 11, 2013 | 09:52 AM
lrs52200's Avatar
lrs52200
1st Gear
Default Battery Light Illuminated
This is my first vette, and my first post to this forum....
I have a '91 convertible C4/V8 (used to be my late husband's - not that it matters but he was the only owner).
It hadn't been started in about a year and of course it was dead so I put in a new battery yesterday. The moment I started the car, the brake light came on. Could this in any way be related to the battery change??
Sorry for the noob question, but I just can't believe my luck is THAT bad that the brakes need attention too! I drove it around quite a bit yesterday and the brakes were fine.
Old Jul 11, 2013 | 10:15 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Check to assure that your parking brake if working AND that it fully disengages when you take the P-brake off. If it is ON only a little bit, the BRAKE light will be on. Check it out.....
Old Jul 11, 2013 | 10:18 AM
Kmcoldcars's Avatar
Kmcoldcars
Is it possible the parking brake was on. That will light up the brake light on the dash.
The parking brake is on the outer side of the drivers seat. To apply it you pull it up, then it will go back down out of the way. To release it, pull up until it stops moving easily, then pull just a bit more and push the release button on the top.
If the parking brake was on you probably did not hurt anything while driving it.
To Battery Light Illuminated
