I have a 87 coupe, when the car is in park and turn the wheel in either direction there is a popping sound from the front end. I checked the power steering fluid and it is full (changed out all the fluids when I got the car). The sound was there before I changed out the fluid. Is this a rack and pinion going bad? Standing at the engine bay when the wife turns the wheel the sound seems to be at both front wheels. You can feel the pop on the wheel when it sounds off.It does not leak and steers normal going down the road. Never had a car with a rack and pinion that's why I ask.
you might try bleeding the air out by jacking the front wheels off the ground and then turning the steering wheel back and forth lock to lock a few times
Thanks for the suggestion, am I to take the cap off the power steering fluid for the air to escape or am way off base here?
Yea, with a 87 I have some checking to do. If the rack and pinion was going out would it leak first?
No. I just had mine rebuilt and it never leaked a drop. I would do as suggested and check tie rods, ball joints and bushings. Also check the intermediate shaft that connects the steering column to the rack for play.
The cap has a vent hole in it. No need to remove it.
One thing you can do with the cap off is to look for air bubbles (not good) in the fluid while the engine is running. Usually that causes a moaning noise.
Another tip is to use a thin vacuum hose similar to a stethoscope,
put one end up against your ear and the other end to search around for the noise. Also check the intermediate shaft between the steering rack and the steering column, it can wear allowing some twisting movement and noises. Otherwise most common things to check is noise from the ball joints or rack at the input shaft.
ball joint is super loose or a bushing is out from a control arm. Either is not good and can be the source of cascading problems. if one suspension part wears out it tends to cause adjoining parts to become stressed and fail.
The hyd system has nothing to do with this.
Look at the sway bar link bushings as well.
get the hood UP, have someone work the steer wheel back and forth to create the POP while YOU get your face down there and LOOK & LISTEN. When you think you have found which wheel, and maybe which part, jack it up and grab the wheel and jerk it around. Loose parts will reveal themselves with no load on the tire. IF you feel that wheel move or loose in any way, something is wrong and needs immediate attention. Loose suspension causes accidents.
Good advice, I only drive it on the weekends but I will have to correct this problem before anymore weekend drives. I gave it a quick look yesterday while the wife would turn the wheel. One good observation was the ball joints have screws instead of the factory rivet's. This weekend I will jack it up and remove the wheels to see what I can find.
