'93 won't start when hot
Old Jul 15, 2013 | 12:06 PM
4953mark's Avatar
4953mark
Default '93 won't start when hot
I just bought a '93 and it appears that the ccm stops sending data when the car is hot. ccm replaced and problem still continues.
car is at chevy dealer.
thanks,
I am new to the forum
mark
Old Jul 15, 2013 | 05:41 PM
93 lt1 vette's Avatar
93 lt1 vette
I had a similar problem. Opti would lose the high res signal when it heated up and the ECM would kill the spark like the key was turned off. Mine threw codes 36 and 41. Hope this helps.
Old Jul 15, 2013 | 06:06 PM
4953mark's Avatar
4953mark
thANKS FOR THE INPUT, I AM PRETTY SURE IT IS FUEL RELated
Old Jul 15, 2013 | 11:31 PM
jabez's Avatar
jabez
Your ECM is going out. Had same problem. Until I could find a replacement I parked under trees and in shady areas to cool off ECM.
Old Jul 17, 2013 | 03:43 PM
LarryShivers's Avatar
LarryShivers
I had the same problem with a 1990 corvette. Would not crank once it got hot. Checked the injectors and they checked OK, cold. Check them once the engine warmed up and one was totally dead. Replace the injectors and it is cranking and running fine.
Old Jul 17, 2013 | 05:32 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Check ICM & coil.
Old Jul 17, 2013 | 07:53 PM
Hot Rods's Avatar
Hot Rods
Please let us know what fixed the problem
Old Jul 18, 2013 | 08:19 PM
1993C4LT1's Avatar
1993C4LT1
Originally Posted by kimmer
Check ICM & coil.
Old Aug 12, 2013 | 09:02 AM
chopperclay's Avatar
chopperclay
I'm having the same problem with my 93. Just installed a new Petris Optispark and I was hoping that would solve the problem. It didn't. will check ICM and coil and injectors
Old Aug 12, 2013 | 11:06 AM
scotth48's Avatar
scotth48
Check ICM & coil.
I had a problem on my '93 and thought it was the opti and it was the ICM. I put in a new one in and a coil. I also installed a nylon washer to space the coil bracket from the head so it would not absorb as much heat from the engine, Not enough lubricant on the back of the ICM can cause the unit to go bad, thus making it work ok when cold but not when it gets hot.
Old Aug 12, 2013 | 11:58 AM
chopperclay
Default 93 Hot Start issue
Thanks so much, I was very much in need of some direction on this and will certainly check the ICM and Coil out. I know the coil looks like it has had better days and may even be original for all I know. Thanks Much!
To '93 won't start when hot
