Interested to know if anyone here is running this manifold?
How does the OEM distributor fit or did you have to convert to something else? I am in the process of gathering all of my parts for y rebuild and am ordering a DUI Distributor but don't want to order the OEM style if a conflict might exist.
I contacted First and they said it is tight BUT should work.
I do not have one, but have read up on it quite a bit. It seems most just go with a small cap dizzie to make everything easier, including future timing adjustments, but I'm sure others will chime in. I know there are members here that have this, but I don't recall any of their names.
Good luck with the install and let us know what you think once its completed!
Thanks. I checked with DUI Distributors and they gave me the info on the smaller unit. Looks like it is 8 pin module and the large cap is 7 pin. Need to search for an article on a conversion to see how the wiring goes.
