LT1 Injectors
Old Jun 27, 2002 | 05:38 PM
STL94LT1's Avatar
STL94LT1
Default LT1 Injectors
What size fuel injectors do the LT1's have? and how much horsepower can they support?
Old Jun 27, 2002 | 06:25 PM
James94LT1's Avatar
James94LT1
Default Re: LT1 Injectors (STL94LT1)
They are 24lb injectors. As far as how much horsepower? Depends on who you ask, who is doing your tuning etc. I seen they are good to 400hp
in most cases.
Old Jun 27, 2002 | 06:30 PM
STL94LT1's Avatar
STL94LT1
Default Re: LT1 Injectors (James94LT1)
Thanks James
Old Jun 27, 2002 | 06:57 PM
GlockLT4's Avatar
GlockLT4
I believe they were 22# in 92 & 93, then 24# 94-96. I used to have a formula for calcualting hp to injector #, but it's just an estimate, and bigger is always better. If you're staying N/A and under 500hp at crank, 30# should be good. If you have a power adder or nitrous, you are going to need bigger probably. I've seen some guys with blowers running 46# injectors. That's a lot of gas! :eek: :eek:
[Modified by Glock'94, 4:58 PM 6/27/2002]
Old Jun 27, 2002 | 07:06 PM
STL94LT1's Avatar
STL94LT1
Default Re: LT1 Injectors (Glock'94)
Glock, I am planning to have my heads ported and run a LT4 hotcam. I was just wondering if I needed to change injectors.
FYI: My 2001 Ford Lightning came stock with 42lb injectors.
Old Jun 27, 2002 | 07:10 PM
GlockLT4's Avatar
GlockLT4
You can probably get away with the 24#. I have 30# in mine because of the 383. The cam and head work really doesn't cause the engine to need that much more fuel. Unless you're running a big cam.
Yeah, your lightning is blown, that's why i needs the 42 :chevy :p:
Old Jun 27, 2002 | 07:12 PM
STL94LT1's Avatar
STL94LT1
Thanks Glock.
Old Jun 27, 2002 | 07:15 PM
GlockLT4's Avatar
GlockLT4
np
Old Jun 27, 2002 | 07:17 PM
James94LT1's Avatar
James94LT1
I think you should be fine also, if you have alot of miles or something you may want to replace them. I am going with a bigger cam than the hotcam so I am going to 30#'s plus I plan on a 383-396 in the future sometime!
Hey Mike, what do those GM boys think of you driving your Ford to work?
:chevy
Old Jun 27, 2002 | 07:25 PM
STL94LT1's Avatar
STL94LT1
Our parking lot is full of GM trucks, so of course a bright red Ford Lightning stands out like a sore thumb. A get harassed a little, but it is all in fun. I've always been a GM man until I drove this truck, it has massive torque.
Old Jun 27, 2002 | 07:31 PM
James94LT1's Avatar
James94LT1
I bet it does!
To LT1 Injectors
