1987 starting problems
Old Jul 17, 2013 | 12:12 PM
sample45's Avatar
sample45
Cruising
Default 1987 starting problems
Have begun to have starting problems. Engine turns, smell fuel but will not start. It will not start for a day or two, then will start every time for a few days and then nothing again. Over the last few months this has gotten worse. Any thoughts.
Old Jul 17, 2013 | 01:45 PM
AirForceOne!'s Avatar
AirForceOne!
Could be a million different things! When's the last time she had a tune up? Plugs, wires, cap and rotor, air filter, fuel filter.
You shouldn't be smelling fuel unless you have a leak, which is bad!
How old are your fuel injectors? You should test them or have them tested!
Old Jul 17, 2013 | 03:36 PM
playsdixie's Avatar
playsdixie
if you smell it in the engine.check your fuel pressure reg...
Old Jul 18, 2013 | 01:13 AM
Cliff Harris's Avatar
Cliff Harris
Remove the vacuum line from the fuel pressure regulator and turn on the ignition. No fuel should come out of the FPR.
If fuel does come out then the FPR diaphragm is ruptured. Mine started a fire when it ruptured, so check/fix this ASAP.
Old Jul 18, 2013 | 01:26 AM
vetteoz's Avatar
vetteoz
Originally Posted by sample45
smell fuel .
From where?
Engine bay , the exhaust........??????
Checked the simple things like spark at the plugs?
Pulled the plugs to see if they are wet ( no spark ) or dry ( no fuel )
To 1987 starting problems
