1984 Floppy Driver's Side Mirror
Old 07-17-2013, 07:42 PM
GQ-ROD
GQ-ROD's Avatar
Default 1984 Floppy Driver's Side Mirror
1984 power mirror, Got a floppy driver's side mirror,
From the pics below i could see the cross shaped metal piece that has pins that mount the mirror to the motor assembly is broken.
In one pic you can see the pin is still in the u shaped holder.
Is just the pin available ?
Or do i have to replace the whole mirror/motor assembly?
Or fabricate a new pin(s) to hold the mirror on ?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 07-17-2013, 09:00 PM
MotorCity_87_C4
MotorCity_87_C4's Avatar
The Trunion Pins are available, check one of our forum sponsors like Corvette Central. Item# 514534. Be careful removing the mirror, it's easy to break the mirror.
Old 07-17-2013, 09:17 PM
GQ-ROD
GQ-ROD's Avatar
THANK YOU ! will check them out, as for removing the mirror it's only held on with the ball socket correct ?
Old 07-17-2013, 09:24 PM
GQ-ROD
GQ-ROD's Avatar
Just ordered 2 of them from corvette central THANK YOU THANK YOU !!!!!!
Old 07-18-2013, 05:21 PM
Hooked on Vettes
Hooked on Vettes's Avatar
The two studs are part of the plastic piece that is attached
to the mirror. The studs have threads that push into the motor.
When you pull the mirror out of the motor you'll hear a ratcheting
noise.
Here's a thread with pictures of a heated mirror assembly.
http://forums.corvetteforum.com/c4-t...de-mirror.html
Old 07-18-2013, 08:18 PM
GQ-ROD
GQ-ROD's Avatar
noise.
Thank you so much for the link, i was concerned because i only saw one stud in the pic i took and not 2 as i saw in the link for the 96 model.
Will post back when the trunion arrives !!
Old 07-23-2013, 05:28 PM
GQ-ROD
GQ-ROD's Avatar
Trunnions came in today,
Install was super easy, came with instructions, a little grease, slight pressure with the palm of my hand and in it went,
Just need to get a new toggle switch, left and right works on both sides, but not up or down.
THANK YOU, THANK YOU !!!!!!!!
Old 07-23-2013, 06:50 PM
tlfreak
tlfreak's Avatar
why isn't this in faq's excellent pics and write up on how to fix a common problem
Old 07-23-2013, 07:45 PM
GQ-ROD
GQ-ROD's Avatar
Linky no worky ! lol
Old 07-29-2013, 03:49 PM
GQ-ROD
GQ-ROD's Avatar
Update:
Power mirror toggle switch came in today,
Installed it ( PITA ) !!!
Before i replaced the switch both sides moved left and right but NOT up and down.
Passenger side NOW moves up and down and side to side !
So that's good !
Driver side mirror moves side to side BUT not up and down.
I can hear the motor click in both up and down toggle switch position but no movement.
Do i need a new driver's side power mirror ?
Old 07-29-2013, 04:28 PM
GQ-ROD
GQ-ROD's Avatar
Ok seemed i may have answered my own question,
Took the mirror out,
Pulled out the pin that is for up and down,
Tested the motor.......IT WORKS !!
The problem though difficult to see in the pics is that the pin is stripped on 1 side only and on the bottom threads.
So just need to get this pin and it should work.
[IMG][/IMG]
[IMG][/IMG]
This is the back of the bad pin ! which shows good threads on one side, stripped or flattened threads on the other !
[IMG][/IMG]
[IMG][/IMG]
To 1984 Floppy Driver's Side Mirror
Quick Reply: 1984 Floppy Driver's Side Mirror
