Jacking a 1989 Corvette
Old Jul 21, 2013 | 06:35 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Default Jacking a 1989 Corvette
I was wondering what height jack I could use to jack up my 1989 corvette. Would a jack that is 5 inches tall like most common jacks work? I don't have a lot of money and can't afford any expensive "low profile" floor jacks.
Any help is appreciated.
Thanks, Stephen
Old Jul 21, 2013 | 08:10 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default no special hydraulic jack needed
Veryevilkitten2,
No special jack is needed, as I use my regular floor jacks (unlike for the C5 which needs a special low jack).
However, there have been reports of cracking the targa top (clear or blue acrylic) if jacking the car up unevenly.
So, I ALWAYS jack up the front with TWO hydraulic jacks, place shorty jack stands, then the back.
Old Jul 21, 2013 | 10:06 PM
OldCorvetteFan's Avatar
OldCorvetteFan
I generally jack from the mid point between the jack points, but I've also jacked at the rear jack point as well as the front jack point.
And I've jacked with the targa top installed under those conditions, and never worried that I would damage the car.
Those legendary "I broke my C4 because I jacked up one corner" discussions always appear heavy on legend, and very light on facts. Given that Chevrolet put ONE jack in each car, and provided NO instructions cautioning the owner to exercise caution (in the form of loosening the top, or popping the hood, or the hatch, or the doors, ... etc) leads me to believe that there is no problem.
In fact, several years ago, I was at an NCM function, and I had the pleasure of meeting Dave McLellan. I asked him about this myth, and he was astonished that anyone would believe that the car would be damaged by jacking it up. He then recounted that during development and testing, they were always jacking up one corner or another - with NO issues.
Time to kill the myth!
Steven
Old Jul 21, 2013 | 10:15 PM
mazdaverx7's Avatar
mazdaverx7
when not using a lift i have always jacked my C4's up on the frame section at each corner..with the top installed tightly. never had any issue what so ever.
Old Jul 22, 2013 | 07:41 AM
Lucky86's Avatar
Lucky86
Thanks for the info fellas
Old Jul 22, 2013 | 10:09 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Steven
But you know what happens once it gets on the internet.
This myth (and many others) will never die.
Old Jul 22, 2013 | 10:20 AM
garryowen's Avatar
garryowen
Steven
this is the way i raise mine also. noticed when raising to put jack stands under, when jack one corner, the other wheel would come up to.
just moved jack to center and raise a side a a time. works well for me
Old Jul 22, 2013 | 10:57 AM
DucXL's Avatar
DucXL
And lift the car from the thin ridge right at the jacking point nomenclature.I used advice here to position the jack under this thin ridge directly in line/w the rear view mirror.That lifts the whole side of the car.Just obtained my SECOND C4 and found YET AGAIN where some PO had tried lifting the car from beneath the floorPAN!! I see more RTV and cracks.NEVER lift from the floorPAN,use the THIN ridge where the wording ">>jacking point<<" is.
Old Jul 22, 2013 | 11:20 AM
garryowen's Avatar
garryowen
i go a little father back than that to get a better balance, maybe 4"
but as you stated--I ALWAY MAKE SURE I HAVE THE JACK ON THE MEAT OF THAT THIN RAIL.
Old Jul 22, 2013 | 11:25 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If your jack is too high, drive the car up on some wood to gain the clearance.
Old Jul 22, 2013 | 11:46 AM
KYC4's Avatar
KYC4
I jack my '84 up by the front cradle/frame as an entire section instead of on one side only and then place a jack stand underneath each A-arm. I admit I bought into the myth and have just chosen to play it safe. Read (and have seen) too many C3s all screwed up due to mis-jacking the car up.
That is great info about Dave McLellan and his thoughts/reaction to this myth.
Later,
Lee
Old Jul 22, 2013 | 11:57 AM
c4cruiser's Avatar
c4cruiser
Steven
Some people do continue to believe this and it may keep some from working on their own cars.
I also jack up my C4 from the side, mid-way between the embossed jacking points. Doesn't hurt anything and I don't open doors, wind down windows, or release the hood.
What you do need to watch when jacking at the mid-point is making sure you don't place the jack pad directly under the small stud that holds the fuel lines (passenger side) and brake lines (driver's side). Also don't place the jack pad so far under the car that it contacts the floor pan.
For the OP, look at the aluminum jacks from Harbor Freight. They aren't expensive and even the so-called compact versions will easily lift one side of a C4 or any other Corvette. You do need to get some good jack stands to hold the car.
To Jacking a 1989 Corvette
