brakes are smoking
Old Jul 24, 2013 | 07:49 PM
MatthewEdward's Avatar
MatthewEdward
Default brakes are smoking
My front left brake is smoking and is letting of an electric fire smell. How do a fix this?
Old Jul 24, 2013 | 08:34 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Apparently 1 of your front calipers is not working. It happen to me when I was autoxing, my rear rotors were out of spec and the front was doing all the work.
Old Jul 24, 2013 | 10:38 PM
vetteoz's Avatar
vetteoz
Originally Posted by MatthewEdward
My front left brake is smoking How do a fix this?
Jack car up , see if wheel can be turned freely (unlikely )
Most likely the caliper is locked in the ON position.
Investigation needed
Caliper may need rebuilding (old age ) , may be a damaged flex line acting as a one way valve and not allowing the caliper to retract
Old Jul 24, 2013 | 11:52 PM
kimmer's Avatar
kimmer
Or the other side is not working and the one smoking is doing all the work.
Old Jul 25, 2013 | 04:43 AM
Cliff Harris's Avatar
Cliff Harris
The brake line may be clogged internally, keeping the brake pads "on".
The rubber brake lines are actually two lines, one inside the other. The internal line can clog without the line appearing to be bad.
Old Jul 25, 2013 | 05:07 AM
vetteoz's Avatar
vetteoz
Originally Posted by Cliff Harris
The brake line may be clogged internally, keeping the brake pads "on"..
What I already said
Old Jul 25, 2013 | 10:25 AM
383vett's Avatar
383vett
As mentioned, could be the caliper, brake line or abs unit if you have one.
Old Jul 25, 2013 | 11:22 AM
MatthewEdward
Also sometimes my brike pedal will swoosh and go to the floor and still work if I press it hard. Also feels like im hitting the brakes on a warped rotor while driving, feels like I hit a bump every second repeatingly. Car drives much smoother when the brakes go to the floor board
Old Jul 25, 2013 | 11:35 AM
383vett's Avatar
383vett
Sounds like you better get it fexed before you go through the windshield.
Old Jul 25, 2013 | 12:09 PM
WW7's Avatar
WW7
Or the back end of another car.......WW
To brakes are smoking
