Need help with center console shift indicator for an automatic 1990 Coupe
Old Jun 28, 2002 | 12:44 PM
chuckster's Avatar
chuckster
Default Need help with center console shift indicator for an automatic 1990 Coupe
My wife just told me the little red position indicator is not moving to show what gear the car is in...I had the that cover off yesterday taking a bunch of change out of there that had slipped though..
Again, this is an automatic...
Does the dash show shifter position?
Could I have messed anything up? What gives?
Old Jun 28, 2002 | 12:52 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Need help with center console shift indicator for an automatic 1990 Coupe (chuckster)
You have to take the center console apart and re-connect the needle. When you lift the center piece the needle comes out of it's little pocket. Take your time, go slow and you'll get it back in on the first try. Also check the little light that illuminates that window and make sure it's positioned correctly too.
Old Jun 28, 2002 | 12:54 PM
chuckster's Avatar
chuckster
Default Re: Need help with center console shift indicator for an automatic 1990 Coupe (War Machine)
Thanks!!!!!
At least I know it was me....
What a spaz I am.. I did not even notice that...
Old Jun 28, 2002 | 01:04 PM
War Machine
You're not alone, I've done it twice. :lol:
To Need help with center console shift indicator for an automatic 1990 Coupe
