Unplugging MAF
Old Jul 27, 2013 | 03:14 PM
Wirelessrat's Avatar
Wirelessrat
Default Unplugging MAF
What happens if you unplug your MAF and let the car idle in park?
Old Jul 27, 2013 | 03:54 PM
Wirelessrat
Wondering what RPM does it idle at and is that RPM stable?
Old Jul 27, 2013 | 05:56 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
It should go into "fault" mode and run off pre-loaded fueling tables. Depending on the temperature/climate vs those tables, it SHOULD run fairly well. Not great...just OK.
FWIW, the car is drivable w/o the MAF too.
Old Jul 28, 2013 | 04:13 AM
Cliff Harris's Avatar
Cliff Harris
I had disconnected my MAF during a troubleshooting session and forgot to plug it back in. I drove the car to work the next day and couldn't tell it was unplugged.
Unplugging the MAF will NOT put the ECM into LIMP mode. It knows there is a problem and uses the TPS position to guess what the airflow is. It will set an error code.
To Unplugging MAF
